Results 1 to 8 of 8
Thread: Gasket material for fuel.
    20th June 2011 - 20:27
    Dog Rooter, 1290 SDR
    Marton
    I need to make a gasket for a fuel tank. What is the best product to ise and where to buy it from. Ta
    Its not an gasket I can just buy.
    Sent from my M5 Note using Tapatalk
    If it's a gasket that's going to be permanently wet, I don't know. The only fuel resistant gasket sealant I've ever found is the Loctite purple instant gasket. That'll even stand up to Methanol.
    Since the late 70's everything designed to be wet has had an O ring seal - that I've seen anyway.
    Might be worth asking a local outfit who do in tank injection pumps what they use.
    1st March 2017 - 06:23
    round the back
    Why not paper, will it wick?
    Brakes as new
    https://online.flippingbook.com/view/287372/
    Nitrile sheeting should do the trick, that and a wad punch or two. Draw it and get Shuk to cut it.
    Marton
    Thanks for that. They are local to.
    2nd March 2018 - 15:32
    1998 Yamaha R1
    Yeah, nitrile is the Right Stuff. EPDM for coolant and brake fluid.
    An ex Mobil engineer told me to use Loctite Master gasket when I reused my Yamaha gasket, so as usual Grumph is on the money. Lasted.
    6th June 2008 - 17:24
    The Vixen - K8 GSXR600
    Behind keybd in The Tron
    You would need to watch what kind of material you mix with what kind of fuel. Alcohols and Benzenes dissolve different things.
