Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Electrical Wall Switch Help
    26th February 2007 - 23:15
    In the rubbish bin
    NZ
    Working on renovations, and got three wall switches like this one in the house - what if any country/standard are they from?
    Been asking a few mates but they are all mechanics and fabricators and have no clue.
    Wanting to swap all switches in the place with touch switches and smart switches.
    Hole in wall is about 90x90, faceplate is 115x110, and screw holes are 46 horizontal across and 85 vertical
    Thanks
    Find out more at www.unluckyones.co.nz
    20th September 2015 - 11:08
    2017 Triumph Tiger XCA
    Looks like bog-standard switches from the 1970s. PDL?
    Sent from my OnePlus7T using Tapatalk
    Quote Originally Posted by The Lone Rider View Post
    Thanks
    Take a switch into an an electrical supply outlet and ask for the fittings you want ... and fittings you need to install them. That type of switch is common throughout NZ.
    In the rubbish bin
    NZ
    Yeah I've attempted to track down an electrical supply place I can go into with some photos and face plate, but haven't found one that is open at hours I'm not working.
    Just the three are like this. All other sockets and plugs are the same as you'd get anywhere in NZ and same as my other two places.
    Bunnings or Mitre10 might have what you want. Or know who will ... or just google electrical wholesalers for your area.
    In the rubbish bin
    NZ
    Nah, thats why I thought I'd ask here. They only have standard NZ fittings found in most homes. Common NZ size is 75 x 115, making them too small for where these ones are
    Might google wholesaler and see if they can help over email though
    28th May 2006 - 19:35
    suzuki
    lower hutt
    nz pdl switch from the era, you'll need an invoc adaptor plate as you can't buy wide switches any more, this will take it down to a single size, or patch up the gib around it and put a single flush box in. go to an electrical wholesaler for this and the switches, the hardware shops will not have what you want.
    suzuki
    lower hutt
    was common, no longer available
    In the rubbish bin
    NZ
    Thanks, thats more along the lines of the information I'm after
    Is invoc short for something?
    In the rubbish bin
    NZ
    suzuki
    lower hutt
    you got it made in nz and a better product than the other ones that do that job.
    I doubt if one mounting box fits all switches. The various switches will have their own.
    R Redpath Limited are a South Island electrical firm I found quite useful. That wont help much if you're on the other island.
    suzuki
    lower hutt
    I've been a sparky for 41 years, wanna lay a hundy on it? the pdl ones dont without a modification, but some guy in lower hutt designed this one so it will. remember, the walls you fir them on fit them all, why can't these?
    Quote Originally Posted by jellywrestler View Post
    I stand corrected then ...
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    The only non "standard" wall boxes I have seen were for Ring-Grip "Champagne" series switches and sockets. Square rather than rectangular. Took a whole lot out of the house and replaced with standards.
    (PostalDave on ADVrider)
