Results 1 to 2 of 2
Thread: Parts commonality GSX250FM Across
    24th July 2005 - 17:17
    1992 Suzuki GSX250F
    Gore
    Hi guys,
    Ive got a 1993 GSX250FM Across, its had a bit of battle damage and am looking for various bits and pieces.
    I was wondering if there were any parts common to other bikes (GSXr250, earlier GSX250 etc).
    After some front forks, clutch/front sprocket cover plate, brake lines (front and rear), front disk (needs to be more than the 4mm lower limit), rear disk (not too grooved), lower chin/bellypan fairing and windscreen blade.
    Any thoughts???
    Cheers
    4th November 2005 - 14:21
    GS125 and GP100 buckets
    Back when I had one (years ago), the GSXR250 (the steel frame, 2x2barrel carb model, not the alloy frame GSXR250RR) has the same motor and frame as the Across (GSX250F). Fairings and other fittings may be different. Interestingly, the GSX400X Impulse/Repulse/Insult motor will fit in there with minimal modification, as it is pretty much the same frame as well.
    Cheers,
    FM
