Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Briggs & Stratton engine parts
    12th September 2003 - 12:00
    Katana 750, VOR 450 Enduro
    Wallaceville, Upper Hutt
    Well the lawnmower engine's shit itself. Blue-white smoke pouring out, and it keeps oiling up the plug really quickly.
    My guess is the oil ring's gone, so I'm going to pull it apart and rebuild.
    I'll rehone the bore, throw in some new compression and oil rings, and redo the gaskets. No bearings in these motors I've heard so should be a piece of cake.
    I've been quoted some prices for these parts, which seem a bit pricey:
    $82.00 ring set (2 x comp, 1 x oil)
    $35.00 head & sump gaskets
    $11 bottom seal
    It's a B&S XTE55 5.5HP model 128802 type 1119.
    Can anyone recommend a better source of parts, or this a good price?
    And I to my motorcycle parked like the soul of the junkyard. Restored, a bicycle fleshed with power, and tore off. Up Highway 106 continually drunk on the wind in my mouth. Wringing the handlebar for speed, wild to be wreckage forever.
    - James Dickey, Cherrylog Road.
    25th October 2002 - 17:30
    GSXR1000
    Can't help ya on the prices but your post reminded me of the first time I saw the insides of an engine. Aged about 8, B&S 4hp engine on our go-kart, took it apart more times then I can remember.
    3rd September 2005 - 08:19
    Can't ya get Briggs and Stratton parts from AMPS?
    The rings sound a bit pricey,but they are genuine B&S,not much after market for these things.They have an alloy bore,so careful on the honing - gentle glaze bust with a bottle brush hone on a cordless drill at low speed,lube with WD40 or some such.
    My old B&S ripped up the bore after an oil change,it has a long crank and I can't find another.I'm getting bloody sick of jogging behind my screaming Victa 550 Pro.
    17th December 2003 - 20:00
    SV1000, RG500, RD350
    I have the B&S (and Tecumpseh) workshop manuals on disk somewhere if that is any use.
    Geoff
    (\_/)
    (O.o)
    (> <) Peace through superior firepower...
    Build your own dyno - PM me for the link of if you want to use it (bring beer)
    13th February 2004 - 06:46
    Forza 155 SE Pit Bike
    Hey riffer, are you sure the motor hasn't been tipped on it's side, possibly for cleaning beneath the mower? The reason I ask is we used to get two a week that'd run oil in through the inlet valve, then when you tip 'em back over, it fills the carb and air filter with oil.
    Side valve motors rule.
    Vote David Bain for MNZ president
    Quote Originally Posted by White trash
    Interesting. I'll check it out Jimmy, but really, its an 11 year old mower and I probably should rebuild it anyway.
    I always store it in the shed sitting normally. I plan to relap the valves when I pull it apart.
    I guess mainly its an exercise in pulling it apart and checking it out - well actually its an excuse for my mate Zain and I to drink steinies and talk shit... well you know how it is
    Honda tinker Guest
    Briggs Rings
    Try mowac Rings and Gaskets they are cheaper
    9th December 2005 - 22:02
    2018 Triump Street Triple 765 rs
    Hauraki
    Quote Originally Posted by The_Dover View Post
    Ditto! Was gonna suggest he just gets an 883 engine and chucks it on instead. They are about the same technology anyway.
    Trumpydom!
    1st March 2007 - 11:30
    2014 R1200 GS, 2007 DR 650
    Whakatane
    Awesome dredge!!!!
    I may not be as good as I once was, but I'm as good once as I always was.
    25th June 2003 - 13:54
    Triumph Sprint ST
    The Huttness
    Well, now that it has resurfaced, Riffer how did it go?
    21st January 2010 - 12:21
    The Black Pearl
    Vegas Az
    Quote Originally Posted by bungbung View Post
    +1 to that
    Keep on chooglin'
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Probably nothing happened and four years later it runs just the same
    (PostalDave on ADVrider)
    I was a helpful bugger in the old days....
    7th February 2007 - 23:38
    F800GS
    My place
    Yebut did you get a long crank for your old briggs and scratchem ?
