Results 1 to 11 of 11
Thread: Small leak from fuel tap.
    9th November 2005 - 18:45
    2005 Z750S
    Hi,
    Have not used the bike for a little while (the Suzuki NZ250 for sale).
    Just noticed a small leak from the body of the fuel tap.
    My Suzuki Factory manual is a bit vague on the workings of the fuel tap, so a question:
    Can I unscrew the tap and replace any O-rings or something?
    (I don't mean the whole tap off the tank, I mean the two screws holding the tap onto/into the body of the tap assembly).
    Is this (O-ring, gasket, ...?) likely to be a part that Wellington Motorcycles would have in stock?
    ...or do I need to replace the whole thing (tap and all)?
    Thanks for any advice.
    Cheers,
    P.S. Is the bleed screw in the bottom of the float bowl replaceable? It leaks a bit too...
    Measure once, cut twice. Practice makes perfect.
    You can buy rebuild kits for popular models. Erm, that might be an issue. I can’t imagine anyone at WMC being slightly interested.
    If you were lucky it may be the same as a DR or something. It's not a vacuum tap is it?
    So the turny bit is held on by a plate with a couple of screws. You can take it all apart & clean it up, maybe turn the face gasket around, but it is the outer gasket that seals it from leaking outside. Sometimes you get lucky cleaning it, on my RS I couldn’t buy a rebuild kit so I replaced the gasket with an o-ring. This sealed it, but does make it a prick to turn. Not a prob on a race bike.
    Obviously drain the tank and/or rotate it so the fuel is not reaching the outlet when working on it.
    2005 Z750S
    Thanks.
    Thanks for the good advice (also received via PM).
    The guy at Wellington MC (I walked over during Lunch) basically said the fuel taps are a single unit, I'd have to get one from Japan for about $200, and there was no way for him to see what compatible models there might be.
    I think the open it up and try to replace the gasket idea looks better.
    Cheers,
    2nd August 2004 - 12:45
    Eeyore
    Otago
    200 DOLLARS !!!!!!!!! bloody hell.
    2005 Z750S
    Quote Originally Posted by Motig
    Yep.
    The parts book he was looking at seemed to show an exploded view of the fuel tap, with numbers for each bit; but he did not seem to want to even explore any possibilities.
    Cheers,
    Tell them you are interested in investing in a Hardleybloodyableson Belt buckle & matching gheyboy chaps & they will perk their ears up.
    2005 Z750S
    Quote Originally Posted by F5 Dave
    To tell the truth: after I had convinced myself I was just GOING to buy a Suzuki, and then went in to talk about buying an SV1000; they were SO interested in me I bought a Kawasaki.
    (Brendan at Sawyers was 66% of the reason I bought what I did; JIM2 was the other 33%).
    Very happy.
    Cheers,
    2005 Z750S
    PART 2:
    Having cleaned up and reassembled the thing, I find it does still have a slow leak.
    But now I can see where from.
    It's where the body of the tap assembly bolts up against the tank.
    Is there a petrol-safe gasket goo kind of thing that I could use to "help out" the rectangular O-rings that don't quite seem to be doing their job?
    Thanks,
    17th February 2005 - 11:36
    Bikes!
    Go to Engineering Plastics with the tap and oring. Tell them it's for petrol. Get a new square section oring. Mission accomplished.
    Failing that clean the area up including the paint & reassemble with some Loctite master gasket & let dry. A petrolchem type friend told me that & I've used it before as such.
    2005 Z750S
    The nearest Engineering Plastics seems to be in Palmy (I'm in Wellington), so will give the Locktite a go.
    Thanks gents.
    Cheers,
