Results 1 to 10 of 10
Thread: Cleaning engine parts for display
    5th April 2005 - 12:57
    In between bikes
    Earth
    Post Cleaning engine parts for display?
    Been granted rare permission to have engine parts on display inside the house
    As expected all parts are dirty (were removed last week) and need to be cleaned up. It is the how to clean them that’s got me seeking advice.
    All parts are identical and are the housing body where the piston operates within (don’t know what it’s called). They've got a chrome bore and alloy body casing and the alloy section has got coolant channels. These coolant channels are partly blocked with iron metal rust growth tentacles. There are also some oil traces here there plus the bore has got black combustion soot deposits. I'm not worried about the scratch damage on the bore from when the engine obviously expired from its youthfulness.
    These parts are also too big to fit inside a plastic bucket, so I'll have to do some serious improvising if they need to be soaked. They would fit inside the metal wash house sink
    What cost effective and easy method can get these cleaned up nicely?
    After they've been cleaned, I'm thinking about either to get them lightly sand-blasted or polished (ideal). Which direction do you think would be best?
    With polishing, all I need is a drill bit to do both the chrome bore and exterior of the alloy casing?
    Thanks
    Last edited by Flyingpony; 19th June 2006 at 16:18. Reason: Added question mark to title.
    90% of the time spent writing this post was spent thinking of something witty to say. It may have been wasted.
    14th December 2004 - 11:00
    VERY hot soapy water should do it...
    1st February 2004 - 18:17
    RC36, WR, RS250, GSXR1000, Duke250, IZH
    dishwasher, but make sure you clean them afterwards with some palmolive etc, dishwashing powder is pretty caustic
    In between bikes
    Earth
    Partially clean one part ... they definitely don't cut the skin ... it's more like a cheese grater approach ... I'll leave the rest till after the skin has regrown ... putting hands in hot hot water is very very painful with patches of missing skin.
    In between bikes
    Earth
    Have partially cleaned the other two parts but not satisfied with the results. DIY at home doesn't have good enough results using tooth brush and an assortment of common house hold cleaners / washing powders. At least this time the skin on my hands didn't suffer much damage.
    The problem areas I've got are:
    • Attachment point of exhaust stains on alloy block
    • Combustion stains on chrome bore
    • Baked on engine/radiator sealant glue
    • Coolant channels
    • Alloy rust
    • Baked on grease/oil on alloy
    • Light rust
    • Probably some other misc stuff not readily visible
    Basically, if you've stripped down a used motor you'll know what I'm looking at.
    Is there another chemical I could use which will clean them up? (Ideally this is friendly on the metals and definitely friendly on the stainless steel washing room tube I'm using)
    Would Soda blasting clean them up? I'm sure sandblasting can do the job.
    How does the price of soda blasting compare to sand blasting?
    How can I polish up the chrome bore at home so it's nice and shiny? Have a drill, a garage, and those dangerous sexy blue overalls.
    Thank you!
    7th April 2006 - 09:17
    1986 Suzuki GN250
    I rebuilt an engine over christmas in Chch. To clean it I used a couple of cans of spray-on degreaser (about $7 each from Warehouse or Supercheap). I sprayed all parts with this, threw them on a trailer and took them down to the Quickwash place just off Moorhouse Ave. The middle bay has a warm-water water-blaster.
    The water blaster has enough pressure to remove skin so a pair of long handle pliers to hold stuff with is a necessity
    4th November 2003 - 13:00
    BSA A10
    You could also trot off to your local engine reconditioner and ask him to stick them in his "hot tank" (or "cold tank") depending on what it is you are trying to clean
    PM me if you want and I can put you on to someone
    3rd October 2004 - 17:35
    If your going to clean alot of parts you can buy a parts washer. Never used one as we have a sink.....
    EDIT: PUT SOME DAMN ELBOW GREASE INTO IT YOU SLACKER!!!
    18th December 2004 - 08:09
    Triumph Tiger
    Texas
    Quote Originally Posted by Kickaha
    Throw some beer at your local engine recon guy and use the part washer and bath for good results, polish can be done with autosol and a 'mop' head on the drill, takes time tho.
    "If you can't laugh at yourself, you're just not paying attention!"
    "There is no limit to dumb."
    "Resolve to live with all your might while you do live, and as you shall wish you had done ten thousand years hence."
    11th July 2006 - 17:01
    FXR1fiddy
    Albany, Auckland
    as others have said, local engine reco place would be best. Find out who the 'bike enthusiast' is there, and approach him with your story, and he should sort you out. Tell him you sweep up the floor, or supply some beer on Friday...or whatever.
