Results 1 to 7 of 7
Thread: Help! 2 stroke problem
    21st November 2006 - 20:56
    1991 Kawasaki KR1-s
    Hokitika
    Question Help! 2 stroke problem
    Hey.
    I'm having some problems with my bike. I'll start at the start. I brought a KR1-S, running fine for a while, then I noticed it started running quite rough. After a couple more (very short) rides I hit a large problem, it would run for 5-10mins and then die. Lose all power. But after a few more kicks, more often than not, it would start up and be good for another 5-10mins. I have done a bit of maintenance. New air filter (crumbling), new reed valves (cracked), new spark plugs (very fouled), cleaned out all the jets (some were blocked), and also all fresh fluids. The pistons seem fine, the exhaust is clear, the power valves are in good nick and move smoothly, fresh charged battery. I'm running out of ideas guys, and would appreciate any help or advice. Oh by the way, it runs clean and smooth now, but it will still die after 5 or 10mins
    Please help me
    3rd October 2004 - 15:45
    Africa Twin DCT.
    Australia 4507
    Gas cap vent maybe....What kind of fuel tap do they have,vacuum operated perhaps.
    13th April 2005 - 12:00
    Enfield cr250r
    Tokyo
    what color dem plugs ??? just a guess ,,,its not flooding is it??
    Stephen
    The answer lies in the plugs ,,,,,
    Most likely a fuel issue. Floats too high - flooding. Possibly. More likely a partial blockage between the tank and carb. Strip the tap, replace the hose, fit a new filter. Use the largest bore hose you can and hold at both ends with worm-drive hose clamps.
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    Yep your running out of fuel....
    Start checking the tank for crap and any kinked or blocked lines and filters.
    If still no luck, set your float levels.
    Good luck!
    18th December 2006 - 06:09
    SRX 600
    Sth Canterbury
    sounds a bit like a sealed fuel tank....put a hose on the fuel tap and run it into a container to make sure youve got continuous flow ....a coil breaking down may be another prob if you find the fuel system ok....good luck
    16th September 2004 - 16:48
    PopTart Katoona
    CT, USA
    Quote Originally Posted by RG100!! View Post
    kinked lines
    I second this as the KR has a horrible problem if someone doesnt notice this while the tank goes on - it folds over the fuel hose
