this is to help if your are ordering pars for your cage
you need as much info as possible
1) get part number if possible or bring it in if possible as well, if the place your are going stocks the same brand this will be sufficent
2) get make, moddle, year and size of engine
3) get engine and chassis codes. they can be found on a metal plate in your engine bay or on your fire wall. if none get the vin number and look open your doors and look by the lock mechinisim on the door and in the car its self
4) these things help depending on what parts are being ordered
-what fuel (petrol or desiel)
-if it has a turbo
-what drive, front wheel, rear wheel or 4wd
-if carbed, multi/twin carbed or injected. injected can be mpi (multi point injection) or efi (elictronic fuel injection)
-if it has ABS (anit-locking brackin system)
if you cant get any of this stuff or still dont under stand bring the vehical in if possible
this gives you a greater chance of getting the right part first time and makes the job easier
hope this helps
