Originally Posted by
xerxesdaphat
Wow that is a seriously similar design, even the frame, to my dear little RS. It's like they just redesigned my bike and put a different style tank and seat on it. Cool. Gives me hope.
That camchain lever, if it's like mine, then you were pressing down on a little wedge, in order to let the bigger wedge (what does the actual tensioning) release. Correct? If so, then don't worry if you munged it a bit, just so long as it's still able to wedge the other slide in place. What that's there for is to stop the tensioner untensioning if the camchain presses on it too hard.
It seems odd that there is a bolt in the manual and not in your engine. Not like they would've changed design for something like that. Did you get the tensioner out? You sure there isn't a hole in it somewhere for the bolt? If so, it's not a huge matter I think, as there will be backwards pressure on it anyway from the camchain.
Are you replacing the camchain? You should do it, it will only cost $80 or so. Very important, might as well do it now while you've got everything apart. That nice new piston could have a couple of dents in it if you neglect that too long (Honda singles are known for their camchain issues apparently).
