+ a Power Commander. The mid-range will be seriously lean and you'll risk burnt valves without one.
It'll help the engine breathe better, though as I said you'll need a Power Commander (or some other fuel injection remapping hardware) to fix the mixture so you don't damage your engine over time.
An engine is just a big pump. Modern exhaust systems have to clean the spent gases as well as reducing the engine noise drastically. Engine noise is why the Bandit is now water cooled. Air cooled engines don't have a water jacket to help muffle the thousands of explosions per minute. Change the exhaust capacity of the pump by removing all the cleaning hardware and the engine is now exhaling differently and that will change the fuel/air ratio. With the correct fuel map loaded in the Power Commander you'll be able to improve fuel consumption, top end power, and the way the power is made. You'll be able to fix the fuel switching that goes on between a closed throttle and a just opened throttle too.
i think i understand that! i will have a read again tomorow when im not so tired.
thanks, lee
i wouldnt want to be caught dead in the same grave as me.
My experience with big suzukis is that they can be REALLY thirsty when spending their time mostly in the last 1/4 of the throttle.
