Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Motor oil or chain lube?
    28th February 2007 - 12:31
    01' NZ Postie CT110
    Ngati Whatua o Orakei
    I have always been applying a aerosol based chain lube on my drive chain but yesterday while going through the Haynes manual it suggested that I apply 20W-50 Motor oil and in brackets next to it it reads "(not chain lube)".
    What's the meaning of this motor oil on my chain?
    Do I keep applying chain lube on my drive chain or do I start squirting motor oil now?
    30th March 2004 - 11:00
    2001 RC46
    Norfshaw
    Ignore the manual - engine oil is messy and designed for lubing engines, whereas chain lube is designed specifically for lubing chains. While the engine oil will work OK, it tends to fling off WAY too readily, which while it's good in that it carries spooge off with it, also means the chain's not protected.
    Use whatever you like, Dude! You know you will anyway...
    ... and that's what I think.
    Or summat.
    Or maybe not...
    Dunno really....
    4th May 2006 - 21:21
    2006 BMW F800ST
    When I bought my bike it had a crack in the engine casing where a snapped chain had hit it.
    This meant the engine leaked oil directly onto the front sprocket.
    cheaper than a scottoiler.
    1st July 2007 - 17:40
    my little pony
    shoebox on middle of road
    Even the chain manufactures and MB handbooks recommend engine oil.
    Any lube is better than none, but the reality is that it is the tensile strength of the links that determine wear rates, if the chain is kept clean.
    O ring chains just happen to have a higher tensile strength which is what you are actually paying for, the o rings are a bonus.
    Std chain tensile is about 6,500 lbs, O ring 7,500 lb and 630 about 8,500.
    If you had a Std chain with a tensile strength of 7,500 ibs (you pay more)
    if it was well cleaned & lubed should last as long as an O ring chain.
    I use PJ1 (the blue stuff) incidentally, & apply it at the end of a ride, when the chain is warm, soaks it like a spounge and sets.
    01' NZ Postie CT110
    Quote Originally Posted by Coldrider View Post
    Sweet thanks.
    I take it when you clean your chain, you use Kerosene?
    The normal rotate chain by hand and scrub method?
    2001 RC46
    Norfshaw
    Yeah, kero is best for cleaning chains, although occasionally I use WD40.
    Or summat.
    Or maybe not...
    Dunno really....
    4th January 2005 - 18:50
    Massey ferguson 7495 dyna-vt
    Norfland
    I used to use on my dirt bikes...chain bar lube...and sticky oil for lubing chain saw bars...it doesn't fling off like regular oil...I currently use chain wax...thats because..its what I have...lol
    I personally wouldn't use straight engine oil...as it gets flung off and on to your tyre...thats not a good thing
    Given the short comings of my riding style, it doesn't matter what I'm riding till I've got my shit in one sock.
    6th October 2005 - 21:45
    none for now
    tauranga
    I once tried to be cheap and fill a scottoiller with engine oil. Made a hua of a mess but I guess it worked ok.
    31st March 2003 - 13:09
    CBR1000RR
    Koomeeeooo
    I have only ever used chain lube, the RF is currently on 35,000 out of the chain and sprockets and is good for another 15,000 at a guess.
    I wouldn't use Engine Oil on the chain for love nor money... It's called "Engine oil" for a reason... not "Chain Oil".
    $2,000 cash if you find a buyer for my house, kumeuhouseforsale@straightshooters.co.nz for details
    my little pony
    The chain manufactures don't promote any proper chain lubricants, i guess they don't want the chains to last too long, OEM chains are usually not that good as MB manufacturers cut the cost of new MB's.
    Petrol and white spirits are carciogenic ( cancer link) so you should not get it on your hands, unburnt kero is not carciogenic, but defats your skin.
    Kero is slightly harder to ignite.
    There is some other degreasing agent called electrosol, very safe you can stub a ciggy out in it, & doesn't evaporate away quickly, but I have never seen it available in small quantities.
    Safe cleaning & lubing=happy chains
    27th July 2005 - 12:00
    Nood Hyosung 2fiddy
    -36.7814, 174.6527
    Keep it clean with whatever you have, dirt and anything (water, oil, lube) = grinding paste, real good for opening up the close tolerances on any chain. You don't need tons of lube on the centre of the chain but don't clean it and forget to do a little drop between the links. Once the lube covers the moving parts any excess will just fling off, hold dirt and crud and cost more, lube after riding and let it set-up not before.
    I'm selling my new riding gear!! Only worn a few times get a deal Kiwibikers!!
    http://www.kiwibiker.co.nz/forums/sh...53#post1414653
    01' NZ Postie CT110
    Yea man, wear your rubber gloves while cleaning.
    18th February 2007 - 20:04
    1989 Honda CBR250R
    North Shore
    I've never used chain oil myself, the motorcycle dealer I purchased my bike from uses chain oil and it's always flung onto the side of my rear tyre. I use blue mobil grease (texture is like spreadable margarine), is this ok?
    Nood Hyosung 2fiddy
    -36.7814, 174.6527
    If you like grease on your tyres it's fine
    Use the right shit, you'd be lucky to get through two $15 cans a year and save that in chains, sprockets and loss of power. Clean is good and with lube, a little bit often is the trick.
    23rd June 2007 - 20:30
    2007 Yamaha R-Sixer
    Jafa
    i use motul aerosol lube and that stuff is great buy mine from motomail it's around $22 a can and last approx six months i use it every 500-1000k's and things seem to be moving freely
