Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Wierd Engine problem
  1. #16
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Quote Originally Posted by MaxB
    Does the CVK40 have the water pipe de-icing system on the KLR?
    Don't think so - sounds a little modern for a KLR. However it does have a smog control system and this page
    http://www.klr650.marknet.us/decalif.html gives details on dealing with it. Note from that page says : "Initially, I'd no intention of removing the KLR's Evaporative Emission Control System. It doesn't weigh much, and seemed to have zero effect on performance. Zero effect until one sunny day, a valve within the system (don't know what this valve's called..we'll call it the "buzzkiller valve" for now) got clogged (after 13k miles) and stranded me at the intersection of Mayhem & Chaos during rush hour. (it just died, showing symptoms of fuel starvation) The KLR had never stranded me before, so this was the fatal mistake for Buzzkiller & his assembly" - which sounds a little like Quasis problem
    (PostalDave on ADVrider)
  2. #17
    10th April 2005 - 20:00
    04 GSXR 1000
    NZ
    Clean the fuel lines get some fuel cleaner stuff from Repco and run it in, check all the usual basics battery, fuses etc...
    Sounds like the circut of fuel isn't flowing somewhere, but as for the backfiring, hmm...it's a puzzler..checked spark plugs?
    You'd think for a new bike it'd be running alot better than that, maybe there are faulty parts or someones accidently put in the wrong wire its hanging down somewhere and its shorting out on something.
    Geez it hurts to think!
    My bass is such a slapper.......I cant stop fingering those strings
  3. #18
    4th January 2005 - 14:49
    2000 Suzuki Gsx 1200.
    Pukekohe and Christchurch
    Hi mate just bicked up a little pockit bike and it did same thing after running it for about 10 min and found it was the air inlet hole in the fuel gap so give that a go hope you have it fixed for the trip
    Allways ride to your skill level and enjoy
  4. #19
    Hi mate just bicked up a little pockit bike and it did same thing after running it for about 10 min and found it was the air inlet hole in the fuel cap so give that a go hope you have it fixed for the trip
