Was about to make a trip to Taupo this arvo, get on bike to start `er up and turn key to on and no Neutral light, headlight is dead too. I kickstart bike, it started fine without choke, and neutal light came on. But as i was warming it up, slightly reving it the tacho meter hardly moved at all, when i give it more gas to 4,000 (where i normally warm it up) its reving way too loud for what it usually does and if i gave it more gas revs finally did jump up to 5-6k or whatever blipping throttle gave for a moment.
Indicator lights work but seem to instead of flashing as normal, more like its shorting out but they stay on. The indicator dash display doesn't blink at all just stays on, and will turn off when i turn indicator light off.
I rode down to the petrol station and filled up, im sure i reset the odemeter to zero, on way home which is a 1min up the road, it says i've done 12ks already (er..perhaps i didnt reset it properly, im sure i did). Bike runs fine.
Does power/electric problems affect rev meter and odermeter readings too?
I took the seat off to check wiring, it looks all normal no loose wires to my (very much untrained) eye. As from what i can see same at behind tacho dash. I've never had any electrical probs to date with. Bike is stored undercover btw.
Could it be the battery needs replacing? i can kickstart it fine. If battery is flat for whatever reason, would this cause my indicators behave as they do? or should they function normally once the bike is running?
Any idea on how much it costs to get a new battery? I'm not sure how old mine is.
Thanks to anyone who can offer me some advice or have had this same problem,
Cheers
Daz
