Results 1 to 3 of 3
Thread: VFR400 Fuel Problem
    23rd January 2006 - 17:32
    1999 kawasaki kr150
    palmy
    VFR400 Fuel Problem
    Hi All,
    The VFR (NC30, 1991) isn't getting any fuel into the carbys. The vacuum hose is connected, however it doesn't have any vacuum on it. Fuel flows fine (all over the garage floor) when vacuum is applied manually. What does this mean? How do I go about fixing it?
    Cheers
    Gary
    Quote Originally Posted by stop_10r_time View Post
    . . The vacuum hose is connected. .
    To what? From the tap to the inlet manifold/or carb?
    29th November 2006 - 11:50
    TE 250
    When u a pai
    The vacum hose you talk about(leads to switch - fuel on and off) could have a hole or crack in it. Take it off blow into it to check. Maybe a bucket of water will help to see if there is a leak.
    Check the attachment on the intake also if it is seated properly and does it also create a vacum
    TMF
