Results 1 to 8 of 8
Thread: Not mechanivally minded has FJ1200 engine problems
    30th May 2007 - 21:46
    2007 Suzuki GSX1400 & 1990 Yamaha FJ1200
    Matauri Bay
    Man down
    My babys gone down Boo hoo(manly Whimper)
    Ridin home on my 1989 fj1200 when it started to make rattling noise in the engine and a lose power, nearly home so nursed it back....when I listened to it seems to be coming from the top of the engine around one of the valves.
    next day I took off the the valve cover and checked for damage but nothing apparent, Checked valve clearance seem ok.
    pulled the plugs and noticed the plug around the noisy valve is sooted and carboned while other three clean and nomal
    If anyone could offer advice that would be really appreciated.
    Dont have the gear fro a compression test would that be the next step......
    P.s not mechanically minded
    I ask for nothing but to ride where ever the road calls
    10th June 2003 - 12:00
    Kawasaki ZX750-H1~2 (Pre 89 F1)
    Quote Originally Posted by H00dz View Post
    Man down
    Gidday HOOdz,
    Yep... Compression test would be next step - although from what your describing the damage has already been done
    The FJ engine is a fairly robust old beast, very basically a bored XS 1100, although I do seem to recall a few of the very early "12's" taking the skirts off pistons, the reason for which absolutely escapes me at the moment
    Perhaps the above will jog someones memory...
    What was the oil level & condition like in the engine before it expired...
    To be perfectly honest it really could be a myriad of things that have gone wrong & without being able to listen to the engine it's almost impossible to diagnose the cause...
    The easiest thing to do would be to have the local Yamaha shop come pick the old girl up - don't ride it to them, & let them have a listen
    Once they have given you a diagnosis you can make an educated decision from there
    Good luck
    Cheers
    To finish first - first you must finish... Oh b.t.w, which way doe's Turn 1 go & whats the lap record...
    13th January 2004 - 11:00
    Honda PC800
    Henderson -auckland
    No matter what the cause of the problem you are going to have to pull the head off anyway.
    Why not whip it off and have a gander.
    My money is on a busted valve stem
    Hey Frosty
    Did you not read that bit, mate !!!
    Just havin a dig
    Cheers
    25th April 2007 - 23:40
    the mighty fzr and gsxr
    central otago
    Quote Originally Posted by Wheeliemonsta View Post
    Hey Frosty
    Just havin a dig
    Cheers
    dont worry bout not bein a mecanic go buy a manual and do it.
    i did and if i can anyone can lol
    winding up stucky since ages ago
    Matauri Bay
    Thanks for the feeback Wheeliemonsta and Frosty, Its sounds like i'm gonna have to take the ole girl on a trailer ride to the nearest yammy dealer for a bit of a poke around.....problem is nearest dealer over 80kms away in Kaitaia never mind
    p.s if there was a break in the stem would you expect it drop into the cylinder ???
    Matauri Bay
    the oil levels were good and I had changed the oil late December (clocked the k's in my workshop manual but too depressed to look at my bike all stripped bare) hadnt been riding much (a couple of days commuting to work with the odd weekend ride)
    Matauri Bay
    Quote Originally Posted by handle6 View Post
    Yea I totally Rock on to that theory,
    I bought a manual when I got it and I'm definitely of the mind to give it a crack....good to have a site where you can ask for some help from some more experienced guys......
    thanks
