Results 1 to 4 of 4
Thread: 1989 FJ1200 Engine problem
    30th May 2007 - 21:46
    2007 Suzuki GSX1400 & 1990 Yamaha FJ1200
    Matauri Bay
    Sorry this is posted twice under general as well....didnt see the heading until I posted.
    Any moderator can you remove from general Sorry !!!
    Man down
    My babys gone down Boo hoo(manly Whimper)
    Ridin home on my 1989 fj1200 when it started to make rattling noise in the engine and a lose power, nearly home so nursed it back....when I listened to it seems to be coming from the top of the engine around one of the valves.
    next day I took off the the valve cover and checked for damage but nothing apparent, Checked valve clearance seem ok.
    pulled the plugs and noticed the plug around the noisy valve is sooted and carboned while other three clean and nomal
    If anyone could offer advice that would be really appreciated.
    Dont have the gear fro a compression test would that be the next step......
    P.s not mechanically minded
    I ask for nothing but to ride where ever the road calls
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Can you do a compression test - maybe a broken piston or ring
    (PostalDave on ADVrider)
    Matauri Bay
    Hey,
    not sure I pulled the signal cover off yanked the spark plug and cranked it over manually the piston seems to operate smoothly but don't know if thats a good thing to do!!!
    any thoughts
    24th January 2008 - 16:51
    1988 GSX 1100FJ Super Tourer
    Chrischurch
    sometimes the noise from the bottom end can travel up to the top end could be something there.
