Results 1 to 5 of 5
Thread: Battery problem
    22nd February 2006 - 20:11
    '02 Kawa' KLX250 & Bucket
    West Auckland
    Battery problem
    Hi guys,
    I think I may have a problem with both of my Bucket Batteries.
    I have tried the charger that came with the bike, the 'trickle' charger I got with the new battery I brought and a higher quality Projecta brand trickle charger also.I check the voltage of the battery with a multimeter, it shows 12.7ish volts.I hook it upto the bike and flick the switch on and the voltage immediatly drops to 8ish volts.Surely this is showing the battery has only been 'surface' charged right?As soon as I flick the switch on the bike off the voltage of the battery drops right down the 10ish volts.
    Any help or a lend of a battery for this weekend would be awsome if you have one spare.
    Thanks
    Gaz
    Been, seen and going next year.
    Paeroa, world famous in NZ
    13th January 2004 - 11:00
    Honda PC800
    Henderson -auckland
    Dude spend ya money and buy one--best bet is a sealed 10ah for a bucket
    You don't mention what bike it is so I've assumed some points equipped dirty 4 stroke thing.
    Try put the ammeter on 20A plug & position & conect the battery via that. If it is drawing amps then you have a short somewhere. Otherwise yes it is dead batteries, not uncommon.
    Hate total loss systems, always cause problems. If you must buy a decent new battery, or two if you don't want to have one spoil your day. Anything less will waste your time & money.
    Borrow one? hahaha. you won't get anything decent. Find a bike or battery shop.
    16th November 2006 - 23:46
    35$ for a little 3ah battery from supa cheap. Glen put one in his RG150, could be ok.
    West Auckland
    All sorted hopefully, brought two 7aH Century batteries today for $58 so pretty pleased with that
