Results 1 to 9 of 9
Thread: Where do I look for new parts for 89 GSX750F
    24th October 2003 - 12:01
    2008 Yamaha R1
    AUCKLAND
    Question Where do I look for new parts for 89 GSX750F
    It's a long story, but to cut it short I went in search of a problem (didn't find it yet) and now I'm going to be looking for gasket kits and maybey some new bits like intake manifolds. As my local suzuki dealer wasn't interested in doing work on the bike ("too old" they said), I'm sure as hell not going there to get parts. Can anyone steer me in the right direction for parts on the web maybe? Aftermarket or genuine I don't care as long as they do the job and the price is right. I'm no mechanic so may be looking for more help/advise in the coming weeks.
    If you can keep your head when all about you are loosing theirs.........it's quite possible you haven't grasped the situation.
    Look here for parts files
    to identify what it is you need.
    While the shop may not want to work on it they should order you parts no problem or just find another shop. They will know if there is aftermarket parts available, just will need to have good details of what you are after & your model.
    2nd April 2007 - 20:22
    BMW K100RS
    Woodville
    what is the bike doing
    those motors are pretty bullet proof, tell us what it is doing and I am sure someone here will have a pretty good idea of what to do.
    6th April 2008 - 15:43
    1980 Suzuki GS1000 and 1983 Suzuki GR650
    Napier
    These guys seem to have a few parts but cost of frieght is high! http://www.babbittsonline.com/
    Boys can't ride broken toys.
    28th April 2007 - 18:39
    2006 Honda Blackbird
    Albany
    Holeshot did some work on my 97 model GSX750F and it is the same model as yours.
    Be interesting to hear what your problem is.
    19th July 2005 - 20:17
    95' CBR900
    Sunnynook
    Wemoto in the UK have bits for your bike on this page.
    I have bought quite a few RC30 bits from them that are hard or expensive to get in New Zealand.
    Have a look on their Ebay page too, they have regular specials of things like brake caliper seal kits, or engine gasket kits.
    Postage is pretty reasonable, and takes around 10 days. Considering some parts ex Japan can take a month.
    vagrant
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    http://www.suziparts.com.au/ specialise in pre-87 parts but they say they do have later stuff as well.Worth a try
    (PostalDave on ADVrider)
    2008 Yamaha R1
    AUCKLAND
    Quote Originally Posted by robinm View Post
    Original problem that bike shop didn't want to know about turned out to be torn diaphram. The "mechanic" who fixed it (replaced it with 2nd hand diaphram) ballanced the carbs with faulty gear and I initially got the bike back worse than it started. Finally got it all sorted. Couple of months later I had the same problem and decided to investigate myself. Found torn diaphram so replaced all four with new set. All was good. But slowly over about a month the problem seemed to return. More investigating, no torn diaphrams so hoped carb ballance would sort it. Borrowed Viffermans carb ballancing gages and noted that 1, 2 &3 were all ballanced, 4 was the only one out. Took this as a sign of possible vacuum leak but couldn't find one so ballanced all four cylinders. Now it runs worse so put it back in the garage and pulled more bits off hoping to find a wee man holding a big red flag pointing to the problem cause that's about the only way I'll find it.
    I'm planning to check the valve clearances and remove the intake manifolds (carbs are already off) to clean and check for perrishing or leaks. Replace manifold gaskets and any (or all) manifolds that require it. Can anyone advise me on cam chain/tensioner replacement. I.e is it a good idea/easy/expensive.
    As you can tell I'm no mechanic.
    29th November 2006 - 11:50
    TE 250
    When u a pai
    I have a set of flat slide carbs you can have. They are off a late 80's gsxr 750
    Mikuni 48b01e7z1. They're 34mm.
    Let me know it could be a good solution for your probrems?
    TMF
