Page 1006 of 2774 FirstFirst ... 65069069569961004100510061007100810161056110615062006 ... LastLast
Results 15,076 to 15,090 of 41606
  1. #15076
    4th November 2003 - 13:00
    BSA A10
    if only you new what you are talking about
    If only you could spell.
  2. #15077
    If only any of you were a good looking as me.
    I have posted the pro anti squat before it Is a balancing act and comes down to preferences there is no 100% right or wrong. (Other than I am pretty)
  3. #15078
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Could you offer something to suggest that Honda tune out 'squat' with big swingarm angle?
    That's quite inflammatory, my experience with this subject is more extensive than most. Care to spell out where I was wrong?
    The big angle can be fine, so long as the front sprocket is high and the line between axle, swinging arm pivot, and front sprocket centre are close to in line with the rider on it.
    But the geometry of the bike is effected more with big compression, ie when the bike is leaned over and there's large g's acting on the suspension. This could be used to an advantage I suppose. By crikey there'd be a shit ton of testing and data logging to paw through. In real terms I expect GP is the only environment that would or has happened.
    we are talking about the bike in the video not tz400 etc , the bike is built for bucket tracks diffient from standard track , i dont got looking for shit on the net and post it. i go for what a have learn't building frames and racing and there is aways more to learn , i look at it as the rear end rise's it pushes the rear into the track whichs keeps the front on the ground for better turning( not running wide). as g forses come into afeck and diffent weights of the bike it will change ( heavy bikes more lightly to swat but a well set bike like motor gp bike look to sit neutral . i dont have the time to sit her blabing on as i have bike to build and learn more . think about what i have put? , i raced guys bikes over the years that say there bike it sliding out , doing all sort of crap , i ride it , go 5 seconds a lap faster and think it go's like a dream . best to get out on the track and do what suit you to go fast
  4. #15079
    7th November 2013 - 19:37
    gpr150
    palmerston north
    john britten could not spell he just got on and did it. to much talk from some people and no do
  5. #15080
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    I have posted the pro anti squat before it I a balancing act and comes down to preferences there is no 100% right or wrong. (Other than I am pretty)
    As is the case with every single aspect of suspension and geometry of a motorcycle. They cannot be built to do everything to it's potential.
  6. #15081
    Exxon Valdez
    wellington
    Quote Originally Posted by steamroller View Post
    Yeah, and his bike rode like a fucken pig.
  7. #15082
    gpr150
    palmerston north
    bang on if you can win with what your on its working
  8. #15083
    gpr150
    palmerston north
    did you ride it
  9. #15084
    Exxon Valdez
    wellington
    did you ride it
    Of course not. Good riders with oodles of talent did instead. They say pretty much the same thing, power to weight ratio is where it's advantage started and ended.
  10. #15085
    gpr150
    palmerston north
    fuck up then
  11. #15086
    Exxon Valdez
    wellington
    fuck up then
    This thread is a resource for people building bikes. Loads of people share what they have learned through experience.
    Try to keep the trolling to other threads thanks.
  12. #15087
    Husa, your memory serves you well.
    TZ, would you settle for a chocolate teapot?
    OK. Guess I'll keep using the correct formula with 83.3 and 550m/s.
    Thanks very much for the other tips in this forum, especially Frits and Wobbly, it's been pretty amazing.
  13. #15088
    " as the rear end rise's it pushes the rear into the track whichs keeps the front on the ground for better turning".
    Thats dead correct except its back to front thinking in my opinion.
    If you have an issue with running wide on exit then you need to look at gaining some front end turn - drop the forks thru.
    Gaining front grip by killing the rear end with anti squat does "work " but in the example I gave with the Frepin, it was loosing rear grip under power when tipped over hard.
    So I didnt try to fix that by reducing the front grip, I dialled in some more natural rear grip by reducing the anti squat % - dropping the rear ride height.
    This works just as well around the sweeper at Mt Welly where even at those slow speeds the suspension is heavily compressed.
    No Mates bike initially used to step the back out when leaned over going as hard as he could around the sweeper.
    Dropping the back gained some rear grip by reducing the anti squat.
    It then started to run wide on turn in,so rather than reduce the good rear grip we had just gained he dropped the forks thu to steepen up the front.
    Now it steered, and had rear edge grip - seemed to work OK, he won on Mt Welly 3 years in a row.
    Same idea with Discombs TZ350 around Hampton when he won the Sheene last year.
    It was pattering and loosing front grip when hard over exiting the sweeper under power - that bike has near on no anti squat at all, so all we could do was reduce the squat by winding in
    a heap of preload and a couple of compression clicks.
    This stopped the rear from squatting so much and unloading the front - then it steered at full noise onto the front straight - seemed to work, he was 3 secs a lap faster than anyone in his class.
    Its always best to try and gain grip to balance out a lack at one end, reducing the grip at the opposite end can and does work - if that all that can be done to fix pig handling.
  14. #15089
    About 22 kg from memory. Nice motor Not sure where Bren is at with his. But it will be further along than me.
    Nsr125 89-91
    NSR125 project:- http://thetrxproject.blogspot.co.nz/...ng-engine.html
  15. #15090
    31st July 2005 - 11:15
    a shed full of crazy shit
    Really? Jason never complained, quite sure Andrew never made those claims...
    Whom are you referring to Drew?
    Yip, and tried to add as much as we can.
    I actually thought it was an interesting thing to discuss.
    Given late model RS125s and TZ125s tend to show this as well.
    The GPR frames feel great on track.
    Streamroller, your only 3rd in NZ (two years in a row) what would you know.
    And don't worry about Glen Williams SVR650....
    Wobs post above makes good sense, I can imagine that the more mass (weight) and more power - loads up the front with too much anti squat and if front end is not setup to deal with it then it will all go pear shaped.
    Owell we will stay away.
There are currently 383 users browsing this thread. (0 members and 383 guests)
