Page 1009 of 2776 FirstFirst ... 95099099599991007100810091010101110191059110915092009 ... LastLast
Results 15,121 to 15,135 of 41630
  1. #15121
    33 degrees is 5.45mm with a 105mm rod so your maths is a bit off because near tdc you get lots of degrees and fuck all mm, its not a simple 180/54 job
    here is a calculator http://www.dansmc.com/mc_software2.htm
    Opps............. Cheers ears.
  2. #15122
    31st July 2005 - 11:15
    a shed full of crazy shit
    Double opps. Sorry Richard.
    So use to using my buzzetti tool and the maths over the phone failed me...
  3. #15123
    All good done me some learning. Bugger though means I have to pull the head off again.
  4. #15124
    Chambers, Fastfred and I got to play with a 50 on the dyno tonight.
Name:	Dyno Graphs.jpg
    Chocolate Fish if you can match the pipes to their dyno curves.
    All this suspension talk is exciting now that I am making progress on the new bike.
Name:	Front Wheel Bling.jpg
ID:	302881Click image for larger version.
Name:	Hollow Bolt Bling.jpg
ID:	302882Click image for larger version.
Name:	Rear wheel bling.jpg
    All adjustable suspension and blinged out with freshly painted wheels and even hollow weight saving sprocket bolts.
  5. #15125
    YSS have a booklet free for download. It's for beginners but explains a lot. Everyone should have it handy.
    Great, found it (I think):- http://www.yssusa.com/suspension_problems.html Thanks.
  6. #15126
    Chambers and I got to play with a 50 on the dyno tonight.
    Chocolate Fish if you can match the pipes to their dyno....
    .....s.
    I'll try for a chocolate fish.
    Blue run second from top
    Red run third from top
    Dark blue run - bottom
    Purple run - third from top
    Green run - top
    But chances are I'm not catching...
  7. #15127
    25th February 2014 - 01:31
    mostly GG 280 trials
    right HERE
    colors in order on the graph and 1st pipe top.
    blue - 5º
    red - 1º
    dark blue - 3º
    purple - 6º
    green - 4º
    2º pipe the curve is not there.
  8. #15128
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    That looks quite good. Dunno where I got YSS from, Robert Taylor has also done one for racers. KSS is what I meant, but full credit for finding that.
  9. #15129
    So you optimised the fuelling and the timing for each pipe ?
    Would seem impossible for the same ignition to work on a pipe that peaks at 10500 and another that peaks at 13500, and I bet all the stingers were different
    so would have wildly varying egts as well.
    But what do I know.
  10. #15130
    Here is the sideways slot on a TM125KZ10B
  11. #15131
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    So you optimized the fuelling and the timing for each pipe ?
    Yeer, hours spent changing jets and adjusting the ignition ....... nar, it was a few bears and a bit of after work fun...
    What we can say for sure is:- the best sounding one was the second to worst performing pipe.
  12. #15132
    If you don't mind me asking do you have a pic of the intake tunnel, its a front intake isn't it?(I'm not a kart guy)
    they run backwards though i guess?
  13. #15133
    Here is the front tunnel.
    The crank spins forward as normal, so the ramps over the crank shield the intake flow from the turbulent boundary around the wheels.
    The rear slot lets "flow" from around the crank up under the piston.
    Mr Thiel tried the shields on the Aprilia and found some power as well, but dont know if the sideways slot was tested at the time.
  14. #15134
    The crank spins forward as normal, so the ramps over the crank shield the intake flow from the turbulent boundary around the wheels.....Mr Thiel tried the shields on the Aprilia and found some power as well, but dont know if the sideways slot was tested at the time.
    At the time Jan was thinking about the RSA inlet disk position and he wanted to find out whether the direction of crankshaft rotation had much influence on the inlet flow. So he put a standard kart engine on the test bench, measured the power, started it in reverse and measured the power again. 'Reverse' , meaning the crank rotating backward, gave one extra horse.
    I discussed this with Roland Holzner of Modena Engines the other day and he told me that they'd already performed the same test at Rotax. Roland said that the negative effect wasn't so much due the counter-flow induced by the crank webs, but mainly due to the fact that the fat end of the con rod was directly in front of the reed case at the moment of initial inlet flow.
  15. #15135
    I mused a while back about a combo of the Swiss Auto V4 mixed with JBB.
ID:	302897Click image for larger version.
ID:	302898Click image for larger version.
    I can't come to grips though how much the flapping around of the unsupported crank might cost in hp.
    but I tried to get my head around if the outer piston ring seal might offer support or more likely just make it bind.
    I even tried to picture an outer bearing outside the crankwheel.........
    I just love the way the swissauto is so compact in width.
    I also know Honda did at least design if not build something very similar a little earlier.
    I found this engine a flying web rotax based v twin.
ID:	302903   Click image for larger version.
ID:	302904   Click image for larger version.
There are currently 85 users browsing this thread. (0 members and 85 guests)
