Sorry all-searched but I can't find it.... What is the relationship between relative air density changes and main jet size change? Was it 5% jet change for every 3% RAD change?
Thanks.
Thanks.
Yep, those best selling toomey's are very thin, with very shalow diffuser, only a little strong in the very end. They are all around power but also make the best peak power of all aftermarket excluding the dune and drag pipes like cpi, sheareer etc. Kind weird how they work so good.
The banshee fires sparks at both cylinders two times per rpm right!? So a simple ignitech DC-CDI-P works there if setted for two sparks for rpm?
On the inside it is also hot as hell.
You've got that right, TZ. But how do you achieve that? The same way as on a piston crown: polish it.
Shiny surfaces won't absorb any heat; they will just reflect it, and as soon as the heat is gone, so is any reflection.
i recall atleast one honda engine (cr500) used the same old fashion angles and its a bugger to correct. lift the cylinder slightly to fix the floors and then your limited on the roof angles (unless you sky jack the timings well above 130*). leave the cylinder low to get a decent angle on the roof and your floor angles are shit. honda must have known these angles were no good because im not sure they did it on the 125 or 250cc mx stuff. between lifting and grinding i was never able to get over 20* on the A port and the floors werent quit right either. i gave up and moved on to other engines
while im thinking of it, you got any recomendations for a good banshee drag racing pipe ? im just getting familiar with the banshees
Just one thought to add to the 125 stroke thing - the Aprilia made peak power at 12800 and reved to 14500, if we tune the long stroke in a similar
fashion we will have peak HP at 11800 and peak revs = 13500 to give 26M/Sec.
Peaking at a lower rpm will necessitate cranking the bmep thru the roof,and no one has been able to better the Aprilia BMEP at 12800rpm so who thinks they can do better than Jan Thiel et al.
Not me for sure.
The jetting rule of thumb for diameter based jets as we would normally see in a Keihin carb on a well tuned engine is a 3% change in RAD = 1 jet change.
The ceramic coating works to keep heat from raising the temp of the base material - the ceramic surface IS hot as hell ie NFG for a 2T EX port nor in the squish
band of the piston/head - go coat the rest of the combustion surfaces if you want, but not the squish area - it CAUSES deto, been there, blown that up.
Yes polishing the piston and the chamber reflects the radiated heat and reduces the thermal load, ceramic coating the entire chamber area ( less a ring around the squishband ) works more effectively.
The Banshee has wasted spark, a completely dumb idea invented by accountants.
The much better way is to cut a slot in one lobe, making it 3 equal gaps ie lobe/gap/lobe all the same,then program a P2 to fire 2 coils with 3 lobes.
The split lobe is cylinder 1, I always make this the LH side.
Hot as hell is probably a bit of an under statement. I realise that the air charge goes out the port and back so the inconel insert idea was along the lines of minimising heat transfer as opposed to removing heat (and simpler). Looking at material properties stainless would just as good for a cooler 2 stoke exhaust as inconel.... If it was actually beneficial at all
Instead of ducting and fans etc why not put a temp sensor in the header then when its over say 1000°F turn on a pump that sprays water on the skin of the header, wont take much room or weight and wont block the desperately needed cooling air for the cylinder, will be a bit steamy , but no rule against that in the MNZ book
Sorry ,yes I meant to say peak torque at 12800 where the max bmep is seen.
But still a couple of hundred rpm makes no difference to the impossibility of making the long or short stroke variation " better " than what the Aprilia R&D achieved.
I would suggest the amount of water you would need to carry, the pump and the electrics would negate any gains made by cooling the header pipe. We ran EGT sensors on all engines we raced in Gearbox class. Standard equipment with a micron guage which gave track mapping also etc etc. Most of us had laptops.
Secondly spraying water on hot steel would work harden it would it not?? Generating cracks?
I have always wondered why you guys don't run track mapping on your buckets? With the level if tech in this thread I would have thought it was a must have? Unless you are or its banned??
Anyway just really posted to say there is people like me reading this thread with interest and not posting!
Keep it up great stuff![]()
On a Motorcycle you're penetrating distance, right along with the machine!! In a car you're just a spectator, the windshields like a TV!!
'Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out! Shouting, ' Holy sh!t... What a Ride!! '
There are currently 173 users browsing this thread. (0 members and 173 guests)
