Page 1024 of 2776 FirstFirst ... 2452492497410141022102310241025102610341074112415242024 ... LastLast
Results 15,346 to 15,360 of 41632
  1. #15346
    I'm going to back off for a while; I've been hogging this thread for several days to where the long-time members can hardly get a word in.
    I think you are an asset, Smitty. But in case you really want to cool it here for a while, you might want to spend some time at
    http://www.pit-lane.biz/t117p246-gp1...es-aprilia-rsa
  2. #15347
    26th June 2005 - 21:11
    Honda NSR300 track hack
    Pukerua Bay
    our rules prevent SOME of us from using them in Buckets
    Except cheaters, cheaters use 85s
  3. #15348
    Doesnt bother me !
  4. #15349
    85's .... Hmmmm unrestricted 85's .... a proper unrestricted anything goes 85cc developers class ... yes please ...
  5. #15350
    Smitty, yes, post pictures of odd ball engines please.
  6. #15351
    do any of you guys have experience with these things that go inside the carb bore, either before or after the slide ? is it just rubbish with a splash of snake oil ? i have hard time believing it does anything good. heres the description
    The Quad-Flow Torque Wing has vertical and horizontal air flow stabilizers which increase air flow, air velocity, and fuel atomization, thereby increasing performance. This easy to install device gives a big increase in bottom-end and mid-range torque and performance. It delivers a great bang for the buck! Increases air flow, velocity, and fuel atomization Big increase to bottom-end & mid-range performance Increased torque enables pulling a taller gear Improved throttle response Allows leaner jetting which results in increased fuel mileage Laser cut stainless steel Quick & easy to install Made in the U.S.A.
  7. #15352
    I have a hard time believing it does anything good. here is the description.
    The Quad-Flow Torque Wing has vertical and horizontal air flow stabilizers which increase air flow, air velocity, and fuel atomization, thereby increasing performance. Big increase to bottom-end & mid-range performance Increased torque enables pulling a taller gear.
    This is where a back to back dyno test would be very interesting. I would be happy to help if anyone has one to try.
  8. #15353
    heres one that installs upstream of the carb. yes if anyone has one to test that would be nice to see some results
    The air box is connected to the throttle by the air boot. The typical boot is inefficient in routing the air stream as it snakes around the frame and shock before reaching the throttle valve. The irregular shape of the boot produces unsteady and erratic air flow – turbulence. The result is compromised power delivery.
    The FMF SNAP™ divides the air passage within the boot into quadrants to increase air velocity by directing the air stream and reducing turbulence.
    With improved air flow to the throttle valve, you will experience crisper and immediate throttle response, as well as a boost in the low to mid-range torque.
    Installing the SNAP™ is as easy as installing an air filter in most cases and requires no jetting or fuel changes. Drop it in the air boot and feel an immediate difference at the first crack of the throttle with a healthier pull off the bottom. The FMF SNAP™ is bolt on performance!
    • Better Throttle Response and More Torque
    • Easy Installation
    • No Fuel or Jetting Changes Required
    • Patent Pending
  9. #15354
    • Easy Installation
    • Patent Pending
    If it boosts low end torque then it would be just as easy to put a dyno graph on the PR blurb as it would be to put some drawing ?
  10. #15355
    I had a bit of a Google for dyno graphs. Looking around I realized that a dyno run is usually done at wide open throttle and that something designed to improve mid throttle response needs to be tested at several part throttle settings. A full throttle run would probably not do it justice.
  11. #15356
    I'm rather partial to those turbo spinner fans to put at the end of your exhaust they used to advertise in the 80s. That's where the next performance increase in 2 strokes comes from but it is being repressed by Honda as they have too much investment in the fore stroke IC engine.
    A conspiracy
    How about if the smoothed the intake of your cornflakes in the morning if it could improve the outflow of your waste products before you left the house. Result.
  12. #15357
    i don't see any dimples on it - room for improvement or just the next model "improved" version ?
  13. #15358
    I'm rather partial to those turbo spinner fans to put at the end of your exhaust they used to advertise in the 80s. That's where the next performance increase in 2 strokes comes from but it is being repressed by Honda as they have too much investment in the four stroke IC engine.
    .... I can see you are not a true believer ......
Name:	True Believer.jpg
  14. #15359
    Installing the SNAP™ is as easy as installing an air filter. Drop it in the air boot and feel an immediate difference at the first crack of the throttle.
    • Easy Installation
    • Patent Pending
    Dropping a bath towel in the air boot will do the same. Patent pending.
  15. #15360
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    he-ja
    just took a look at the lads Frits mentioned.
    http://www.he-ja.nl/2007-RS125-intro.htm
