Page 1029 of 2776 FirstFirst ... 2952992997910191027102810291030103110391079112915292029 ... LastLast
Results 15,421 to 15,435 of 41630
  1. #15421
    Link wont work for me. Tried looking around at a few of the other EMOT sites but no luck...
    There is a page on converting engines to RV, but it's about EMOT doing it for you, rather than you doing it yourself.
    There are some bits you can buy from him though.
  2. #15422
    I had a half hearted attempt at running E85 on a 4 stroke.... it makes power. From what i remember it likes 7:1 instead of 14:1 air to fuel. One peculiar thing about that fuel, even though it made more bottom end power... it wasn't crisp and snappy down low. But again. .. i didn't spend a ton of time getting jetting just right. On a 250cc 4strk single it was 2hp better than 93 pump
    Just about 30% more than petrol is correct.
  3. #15423
    Heres some pics of this contraption of mine, if anyone's interested.
    It's a Peugeot Spx 103, a bit modified.
    Stock bike
    Naked
    With fairing
    Previous version of the engine
    New engine in progress, went from this:
    To this:
    In two evenings with a dremel, without the aid of beer, a feat I'm quite proud of.
  4. #15424
    More pics of new engine.
    Just a mockup, but it will be mounted "upside down" with a straight exhaust.
  5. #15425
    Roffe site has them listed as well and on one of the threads the euro or britsh 50cc racing ones he details a few conversions.
    Including for the MB50/derbi /rotary valve/
    he sells the bits as well.
    http://www.vrm.se/
    like everyone else it seems hes on Facebook as well.........
ID:	304741   Click image for larger version.
ID:	304742   Click image for larger version.
ID:	304743   Click image for larger version.
ID:	304745   Click image for larger version.
ID:	304744   Click image for larger version.
  6. #15426
    http://www.vrm.se/
    I appreciate you all trying to help me out here, but I'm not really looking for info on how to do a conversion, I may have worded myself incorectly. I'm just wondering what to go for; a roundish port or one wider at the top. I marked it in the picture.
    Attachment 304702
  7. #15427
    I appreciate you all trying to help me out here, but I'm not really looking for info on how to do a conversion, I may have worded myself incorectly. I'm just wondering what to go for; a roundish port or one wider at the top. I marked in the picture.
    Attachment 304702
    I got that don't worry I was just added in the Roffe stuff cause I hope to get commission...lol
    Fits or jan I think discussed the shape on pitlane probably part one or part two.
    Also this is Jan of FB
    "Jan Thiel" If you use the same diameter for the inlet hole as the carburetor you would need a very big disc diameter, so usually the inlet duct is oval. So it is usually a compromise of available room and carburetor diameter, also thinking about friction...........
    ...........Later the disc diameter was enlarged to 123, later 126, because of the flow loss the 120mm disc caused......
    I understand these inlet ports are ok.......
ID:	304949Click image for larger version.
ID:	304950 Click image for larger version.
Name:	rsw125 side view.jpg
ID:	304954Click image for larger version.
  8. #15428
    No problem!
    I'll see if I can find it!
  9. #15429
    No problem!
    I have a few crankcase and RSW pics and others here.......
    http://www.kiwibiker.co.nz/forums/al...p?albumid=4862
    http://www.kiwibiker.co.nz/forums/al...p?albumid=4839
  10. #15430
    Thanks!
    Seems like roundish is the way to go.
    Am I right in concluding that with the same timing, even though a port with a wider top will open more of it's area early and keep more area open for longer, the better flow and consistent shape from carb trough the intake of a round one is to prefer?
  11. #15431
    Another question:
    The bike I'm building is single variated, variator on the crank fixed pulley on a jackshaft with chain drive to the wheel on the opposite side.
    The whole engine moves towards the fixed pulley when it variates. The engine mount allows for some axial movement, to keep the pulleys aligned during variation. Now to the question; with the variator doing it's thing, force is applied both axialy and radialy, is floating the crank a bad idea? Both crank bearings are press fit on the crank in stock form.
  12. #15432
    The bike I'm building is single variated, variator on the crank fixed pulley on a jackshaft with chain drive to the wheel on the opposite side. The whole engine moves towards the fixed pulley when it variates. The engine mount allows for some axial movement, to keep the pulleys aligned during variation. Now to the question; with the variator doing it's thing, force is applied both axialy and radialy, is floating the crank a bad idea? Both crank bearings are press fit on the crank in stock form.
    Yes floating the crank, normally desirable, is a bad idea in this case. Or rather, the single variator is a bad idea (it's French, you know...)
  13. #15433
    Thanks!
    Yep, not exactly an ideal solution... But it has one advantage over dual variated - you can easily gain some manual control over it with a foot lever.
  14. #15434
    It sounds like you're in the market for a real vintage bike; you'll have manual control over mixture strength and ignition advance too.
    By the way, doesn't 'manual' mean: by hand? I'd love to see you reach down and adjust the gearing coming out of every corner .
  15. #15435
    Footual?
    Yeah, no it's more like this is what I've got, and I enjoy having fun modifiyng it, most of all the learning part of it.
There are currently 60 users browsing this thread. (2 members and 58 guests)
  1. Noxin,
  2. Peter1962
