Page 1071 of 2776 FirstFirst ... 71571971102110611069107010711072107310811121117115712071 ... LastLast
Results 16,051 to 16,065 of 41631
  1. #16051
    Bluur. Eaten too much. Had a quick kip. Kids playing with hot wheels track. Still sober enough for wielding rifflers (wouldn't trust myself with grinder) might have a quick fettle of transfers till next guests arrive. And pack for going to see cmtry cct racing at Wanganui tomorrow.
  2. #16052
Name:	Inlet Injection Manifold.jpg
    Started making myself a twin injector manifold for the Inlet.
    Quiet start to the day, Mass, casual lunch, watched the Queens Xmas speech on telly and the film "Red Dog", worked on the bike in the evening, grand kids tomorrow, perfect Christmas. http://www.dailymail.co.uk/news/arti...s-service.html
  3. #16053
    hi frits it seems your familiar with modena 125cc version. it says max power is 15000rpm . that seems like quit an accomplishment. but what i dont understand is the port arrangment, mostly the transfers. exh opens at 195*, presumably for the main and the flanking ports probly a couple degrees later im guessing. A 130.5*, B 126.5*, C 128.5*. the transfers seem unconventionally staggered compared to what im used to reading about. can you give some thoughts on the theory behind this approach ?
    i almost forgot something else. why only a 106mm rod ?
  4. #16054
    hi frits it seems your familiar with modena 125cc version. it says max power is 15000rpm . that seems like quit an accomplishment. but what i dont understand is the port arrangment, mostly the transfers. exh opens at 195*, presumably for the main and the flanking ports probly a couple degrees later im guessing. A 130.5*, B 126.5*, C 128.5*. the transfers seem unconventionally staggered compared to what im used to reading about. can you give some thoughts on the theory behind this approach ? i almost forgot something else. why only a 106mm rod ?
    I don't know where you read it, Peewee, but maximum power is produced much earlier than 15000 rpm, so you'd better not believe everything you see in writing.
    Other than that I am not going to comment on anything related to Modena for the above-mentioned reason; I can't afford to be quoted at the moment.
  5. #16055
    yes maybe i got some bad information. but thats what it says on their site. read for yourself . click on engine information http://www.modena-engines.it/eng/index.php
  6. #16056
    It says max RPM is 15000. It quotes a max power figure of 44cv (what ever a cv is) but not at what RPM it is made.
  7. #16057
    my bad. i didnt read it correctly. still it lists a strange stagger pattern on the transfers. although the drawing doesnt seem to match as the C appears to be same height as B. im sure frits will clarify it when the time is right
  8. #16058
  9. #16059
    Yes, this is getting exciting.
  10. #16060
    Everyone that works within such small niche technical markets like race engine manufacturing always has to sign a NDA.
    Ive been doing this for years and if you dont abide by the agreement terms, you dont get the work - simple.
  11. #16061
    16th December 2011 - 14:14
    Benelli 250 2C
    44cv
    CV = chevaux - horsepower
    Citroen 2CV ( Deux Chevaux ) = 2 horse power but having driven one I doubt it was that much !!
  12. #16062
    hey wob i figured the case ratio to be 1.43 on this yam. im not sure yet if ill dive in and do any welding to correct the transfers, keeping that in mind do you see any harm if i lifted the cylinders a few mm or would it do better leaving the case volume small ?
  13. #16063
    My own impression: it sounds rather pompous . But like Wob says: you gotta do it this way or not at all.
  14. #16064
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    Hello,
    can someone please tell me the compression height of the aprilia rsa piston? i heard of 24mm but i do not know if this is right. are there 54mm pistons available with even less com height?
    i have another question regarding carb area and its relation to the cylinder intakeport area. should the intakeport have the same area as the carb (i think so) or should it be bigger or smaller for some reason? thanks
  15. #16065
    5th April 2004 - 20:04
    Exxon Valdez
    wellington
    Hey TZ. Is there a chance that the ball valve you're using with the bike injected, is screwing with the air flow at part throttle and causing the detonation?
    I see the two sharp edges creating a wicked flow disruption when I picture the valve partially open, and I recall Malcolm (koba) once showing me a simulation of air going through different shaped carbs and trying to explain the pros and cons of each scenario.
