Page 1073 of 2774 FirstFirst ... 73573973102310631071107210731074107510831123117315732073 ... LastLast
Results 16,081 to 16,095 of 41608
  1. #16081
    Less metal mass in the divider = less heat input = less expansion distortion into the bore.
    But way more important issue is to get the exit area ratio correct, and now the duct needs to be oval with the Aux ports outer wall
    extending right thru the pipe spigot to the header.
    This will need welding top and bottom as the duct exit is too big to start with.
  2. #16082
    now i know why hardly nobody bothers putting extra ports in the stock cylinders. its alot of damn work . got the hole punched through but still along ways to go
    hey it seemed like you posted the duct exit should be 90% of the total exh area at the bore for a mono port if i recall correct. is it supposed to be like 95% if im using 3 exh ports ?
  3. #16083
    Yes, Triple Ex is a lot of hard work. And I think from memory, the smallest point of the duct area as it transitions from oval to round is supposed to be 75% of the total area of all the exhaust ports combined for a 3 ex port setup.
  4. #16084
    The area ratio TeeZee has answered but here is the basic idea.
    The exit area should be related to the Blowdown STA,as rightly pointed out by Frits, but i just havnt got that far yet.
    3 port engines can generate alot more blowdown as well as total Ex STA when compared to a single port setup, and from general observation
    the exit areas of these can , and usually do end up as 100% of the main port effective area - ignoring the Aux area.
    This makes perfect sense when the general rule for the single port is best exit area is at 90% ie less blowdown, less BMEP, less exit area.
Name:	RZ Porting.jpg
  5. #16085
    ok i just converted the duct exit diameter to area mm sqaured. its 77.3% of the total area of all 3 ports. sounds like im not far off from where i need to be
    duct exit diamter 34.8mm = 951.149mm sqaured area
    total area for all three ports 1229.5mm sqaured
    951.149/1229.5 = .7736= 77.4%
    remember the exh is only at 190 right now which wobbly said is to small so ill have to sort that out but if i raise the exh higher then i will probly be close to the 75% without needing to do much to the exit
  6. #16086
    Here some pics (attached)if that helps, its no RSA of course. They I believe had a CNC finished Duct.
    follow the path in this
    http://www.kiwibiker.co.nz/forums/at...4&d=1419235154
ID:	307192   Click image for larger version.
ID:	307193   Click image for larger version.
ID:	307194   Click image for larger version.
ID:	307195   Click image for larger version.
ID:	307196   Click image for larger version.
  7. #16087
    i wont go to all the trouble of cutting off the spigot exit and making a new removable manifold. ill probly just extend the aux tunells pretty far down the main tunell like wobbly drew in the pic
  8. #16088
    sure wish i had a machine like this. hell even a simple drill press would probly do fine with a fixture to hold the cylinder. would save alot of time. machine could do the majority of the work making the rough hole then do the fine details with hand grinder
  9. #16089
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    Did You used exit angle of port in calculations ?? Here's what Woobly wrote when I was asking about this (exh port dimensions)
    In the port STA calculations the programs use the chordal width and the piston movement over the port height.
    If the floor and roof of the duct are parallel exiting the bore then the area is simply Width X Height but if they are angled
    then the height in reality is X the cosine of the angle.
  10. #16090
    i just used the area values from engmod. i assume thats the correct way ? it said total area of all 3 ports was 1229.5mm sqaure. roof and floor angle is around 15* . im not sure how to figure area with cosine involved
    heres a cosine calculator but i dont know what number values to use http://www.calculatorsoup.com/calcul...of-cosines.php
  11. #16091
    Poland
    Cosine of 15 degrees is 0,965925826....
    1229.5 * cos15* = 1187,60. I don't have engmod so I can't tell You is that 1229 vaue already with cosine or without it.
  12. #16092
    http://www.harborfreight.com/5-in-ru...ise-69159.html
    i'm going to have a go with something similar to the top one, to mill a pattern in a drill press as I don't have access to a mill.
    http://www.amazon.com/Wilton-11754-4.../dp/B009E0EBFM
  13. #16093
    Harbor Freight Tools sells cheap stuff mostly made in China. Some of it is good for one offs or home handy man applications but not for serious money making ventures.
  14. #16094
    No Worries tis for wooden pattern for me...........I just can justify dropping mondo money on a decent mill, the rest i can do with a router, im not expecting it to do much else,I know Ya gets what ya pay for.
    I used Harbour Freight as an example for pewee because I guessed he was in the Land of the free and home of Knave, same as you.
    the NZ eq of Harbour freight is http://www.topmaq.co.nz/item/view/10...e?sku=MEVI1900
    Still Chinese but they have this also.
    http://www.trademe.co.nz/business-fa...-829460087.htm
    Compound Sliding Table 450x168mm
    Features:
    - Working area 450x168mm.
    - X-axis travel: 210mm.
    - Y-axis travel: 140mm.
    - Dimensions (LWH): 580x390x80mm
    - Has slotted foot for secure mounting
  15. #16095
    Like any other pipe resonance-dependent two-stroke.
    Sure, also like on any other pipe resonance-dependent two-stroke: programmable ignition, power jet, power valves, trombone pipe.
    But since I am under the impression that you can build anything you can think of: how about shrouds in the transfer roofs? If you lower them, you will lower the transfer timing, so wrongly-timed exhaust pulses will have less chance of shoving fresh cylinder charge back into the transfer ducts. Moreover, lowering the transfer timing while leaving the exhaust ports alone will increase the blowdown angle.area. That will put an end to the dreaded part-throttle detonation that plagued all Aprilia racing engines.
    Taking this thought a little further, you could even use the movable transfer ceiling instead of a throttle.
    That's actually quite hard to do, there is not much room as the exhaust ports are almost right there! BUT I have a plan, as you could imagine. The CNC will come in very handy, are you sure you don't mind me bastardising your FOS system?
    How much are we allowd to angle the transfers up? To give room for the exhausts to angle down over them.
