Page 1088 of 2773 FirstFirst ... 88588988103810781086108710881089109010981138118815882088 ... LastLast
Results 16,306 to 16,320 of 41591
  1. #16306
Name:	A Grade Mid Field 50 - 1.jpg
ID:	307948Click image for larger version.
Name:	A Grade Mid Field 50 - 2.jpg
    These two 50's, ran midfield in A grade, a very good effort.
ID:	307951Click image for larger version.
Name:	Neat Little 50.jpg
    There were other 50's in B grade, I am working on a 50 of my own for B grade, its a great class.
Name:	Starting Young.jpg
    FarmerKen getting his boys started early.
Name:	Fuel Injected 2T.jpg
    Fuel Injected 2T, didn't run that well, started easy and flew on full throttle but I just couldn't get it to come back onto the throttle properly after shutting off. I wanted to be the first person to race a fuel injected 2T in Buckets, well maybe next time.
  2. #16307
    Quick update
    Heres a quick update on my 50cc wierdo french build.
    I've ditched the original spring loaded pivoting engine mount.
    The engine is now stationary (can slide sideways to align the pulleys while variating), and I've fabricated a roller tensioning system to keep tension on the belt, it also has a foot pedal to fine tune on the fly.
    The relief grooves for the disc was cut on a homemade dremel jig in my drill press - worked great.
ID:	307946   Click image for larger version.
ID:	307945   Click image for larger version.
ID:	307942   Click image for larger version.
ID:	307943   Click image for larger version.
ID:	307944   Click image for larger version.
  3. #16308
    Reworked crankcase - intake aimed just a few deegrees up, and a pic of the cylinder, notice the chipped nikasil - might destroy itself pretty fast, we'll see.
ID:	307959   Click image for larger version.
  4. #16309
Name:	Lap Record Breaker KE125.jpg
    Lap record breaker and winner of the first A grade race, Kawasaki KE125 farmbike engine.
Name:	Wills RS-TF125.jpg
    Wills TF125 Suzuki farmbike engined rocket, this bike ran at the very sharp end of A grade gaining several placings.
Name:	Quick MB100.jpg
ID:	307958Click image for larger version.
Name:	Mid Section Muffler.jpg
    MB100 with an interesting mid mount exhaust stinger, works well, very quiet.
Name:	Aprilia TF125.jpg
ID:	307954Click image for larger version.
Name:	Aprilia TF125 Engine.jpg
    Aprilia rolling chassis with a Suzuki TF125 farm bike engine.
  5. #16310
Name:	TZ125 - Aprilia 70.jpg
ID:	307965Click image for larger version.
Name:	TZ125 Engine.jpg
ID:	307966Click image for larger version.
Name:	TZ125 with 70cc Aprilia.jpg
    TZ125 chassis with Aprilia 70 motor, a very business like package.
Name:	RGV100 - 1.jpg
ID:	307963Click image for larger version.
Name:	RGV100 - 2.jpg
ID:	307964Click image for larger version.
Name:	RGV100 - 0.jpg
    H2O RGV100, very nice.
    There were also a lot of very well developed 4T's mostly based on the FXR150 commuter bike.
  6. #16311
    Timing became very unreliable sadly so it would be hard to verify if of was a lap record. I supposedly almost equaled it on the 50. Unlikely seeing the way the fast bikes blew me out of the way at the end of the straight. If you choose tobelieve the times Will supposedly went 2.5 seconds quicker. But I can't deny the pace was fast and Kel was likely quickest on the day.
  7. #16312
    Adegnes,
    Neat pics and lots of thought. Well done. One question: With a downward facing cylinder, do you ever have problems with oil, under that gravity, accumulating in the head and oiling up the plug?"
    Thanks. Ken.
  8. #16313
    Adegnes,
    Thanks. Ken.
    Thanks!
    That might become an issue, this is my first upside-down engine, so I have no experience with it yet.
  9. #16314
    Timing became very unreliable sadly so it would be hard to verify if it was a lap record.
    I think you are right, but a good day never the less, I got to see lots of great people and I met some new faces to. A great meeting all in all. And you were right about that good Thai Restaurant, thanks.
  10. #16315
    . . . .and putting up your tent?
  11. #16316
    It was she who must be obeyed-es idea to tent and had brought one unseen of Trademe.
Name:	Tent Drama.jpg
    I could imagine how it was going to go.
    And I just knew it would be out to get me.
    So I was very very grateful that you were able to subdue it. Thanks.
  12. #16317
    Wow score 12 out of 10 for the milling attachment. I think this configuration of the CVT may be the best for buckets, keep posting stuff please
  13. #16318
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    (Quote) Adegnes,
    Thanks. Ken.
    Lots of light experimental aircraft have used the 'plugs down' setup with good results.The Avid Flyer used a Rotax 532 or 582 in an upside down configuration without any more issues than a 'right side up' set up..
  14. #16319
    Thanks!
    It has one big disadvantage though; shorter range - hard on the clutch if you want good take offs and top speed.
    I'll keep posting!
    Thats reassuring to know, thanks!
  15. #16320
    Wow score 12 out of 10 for the milling attachment. I think this configuration of the CVT may be the best for buckets.
    Yes, the work is delightful. But using one variable and one fixed pully will give you only half the range that you could have with both pullies variable.
    I've ditched the original spring loaded pivoting engine mount. The engine is now stationary (can slide sideways to align the pulleys while variating), and I've fabricated a roller tensioning system to keep tension on the belt
    If you choose to stick with one variable and one fixed pully, ditching the pivoting engine mount is a good idea. And I like the tensioner. But I have my doubts about the sideways sliding engine. It will take some force to make it slide, which means the belt will hardly ever run perpendicular to the shafts. Wouldn't it be even simpler to mount the engine completely unmovable and have the secundary pully sliding sideways on its shaft? That would also avoid the need for a flexible exhaust pipe mounting.
    EDIT: taking this thought a bit further: why not make one sheave of the secundary pully slide on splines, spring-loaded, and the other one fixed to the shaft?
There are currently 57 users browsing this thread. (0 members and 57 guests)
