Wobbly. Are you going to the Phillip Island Classic ?
Na, really pissed as Trevs health is too suspect at this stage to go.
The Frepin is pretty much ready to rock but havnt touched it due to the other issue.
Might need to bolt in a young gun to help on the way to road racing glory.
A little advice from the gurus please...
i have a project on the stocks which will involve casting my own cases etc - not really a problem, but i have a couple of questions on engine architecture.
i want to do a horizontal single - I have a watercooled barrel so i don't think cooling will be a problem and i can always jacket the crankcase anyway.
But - my big question is, "orthodox" side rotary valve or on top of the cases with a downdraft carb ?
which leads to the other question - Downdraft jetski carbs, how tunable ? i've never used them but I'm aware others here have. Budget will not permit injection...
Comments please.
I'm no guru but I do have a few pics
So this might save you a bit of time Yoda claus
http://www.kiwibiker.co.nz/forums/at...7&d=1413067504
http://www.kiwibiker.co.nz/forums/at...6&d=1413067502
http://www.kiwibiker.co.nz/forums/at...5&d=1413067501
http://www.kiwibiker.co.nz/forums/at...4&d=1413067499
http://www.kiwibiker.co.nz/forums/at...3&d=1413067498
http://www.kiwibiker.co.nz/forums/at...4&d=1413067484
or
http://www.kiwibiker.co.nz/forums/at...3&d=1413067365
or
http://www.kiwibiker.co.nz/forums/at...7&d=1420961298
http://www.kiwibiker.co.nz/forums/at...2&d=1420961294
http://www.kiwibiker.co.nz/forums/at...3&d=1420961295
http://www.kiwibiker.co.nz/forums/at...4&d=1420961295
I used to ride a bucket that a mate done with a huge Keihin jet ski carb went very well but had issues over fueling on the overrun....they pump fuel regardless of throttle position. Jennings had a fix for it back in the 70's
Rob has a copy of it I think.
as for reed you could do a Rumi style with a fairly conventional downdraft carb in reverse.
http://i734.photobucket.com/albums/w...nnen0031-1.jpg
OK, thanks Husa. Yes, some nice work there - but what are they ? I see no identification as to what the motors are. And all appear to be conventional side rotary valve. Point taken re the pumper carbs. I may be able to get my hands on an Ibea - any good Wob ?
Some snow as in the pic would be very welcome at present...
Page 1090 ......
Links Posted because I was asked about the det sensor and temp data logger.
Wobbly, I hear your pain
The top ones are a set made using cad then 3d printed in plastic to check then cnc'd they are for a ktm50 cylinder stolen from a thread on pitlane "self designed 50cc" http://www.pit-lane.biz/t3187-50cc-s...cc-race-engine
can't remember if the gearbox was Honda or Derbi or am6. but it looks Honda MB or CR80 early.
later
Then the single pic I forget but Frits won't have...- rotary inlet with 32mm carb
- self designed crankcase (will be CNC machined in the near future)
- main components (crank, gearbox, clutch and so on) from Derbi Euro 3 engine
- cylinder from KTM
- battery ignition and water pump
Then Keidler (gee Greg those didn't need a name as they had names on them)
Then Rumi.
oh one I missed. ....Emot experimental?
I like this one as it is based on circles and with the horizontal cylinder, it can be seemingly made slimmer than with an upright cylinder due to the rv inlet being a head of the primary rather than on top of it.
The Rumi used a Keihin FCR 4T carb that can be run all but vertical, the jets are the same as a normal PWK etc
Mikuni do a similar flat slide carb with a horizontal bowl,but pumper carbs can be made to work very well as every part of the system is adjustable
like the lever height and pop off pump pressure etc.
Ibea flat slide with 3 jets is the real shit as they flow well and are fully tweakable in every respect - especially if its a rare ( expensive as hell ) flat slide..
The only issue is that they need a fairly big bore around the throttle plate and a small venturi in front of that - unless an aux venturi is fitted, then the flow capability is compromised.
The rear RV ( top ) is the elegant solution but I hate the usual right angle belt drive setup that many use after seeing a video of one running
and during a dyno test the belt goes completely spastic at several rpm bands - so how often would that occur in a 30 lap final.
I am doing one at the moment with a simple straight belt on the side behind the ignition and a right angle cylkro gear drive behind the RV.
Thanks Wob. Belts - I remember Dick Hurdeman telling me he had to allow huge valve to piston on the BMS Ducatis as the timing varied to a scary amount when strobed on the Dyno. The Britten had similar probs so twisted belt isn't desirable...
Flettner - I'm stuck with a conventional rotary valve barrel and have no desire whatsoever to cast my own thanks...relevant quote which I'm sure Frits is familiar with - "the first concept of superior principle is always defeated by the perfected example of established practice". Or as Mike Sinclair put it - "you only need a 5% improvement, not a revolution"
There are currently 103 users browsing this thread. (1 members and 102 guests)
