Page 1123 of 2774 FirstFirst ... 1236231023107311131121112211231124112511331173122316232123 ... LastLast
Results 16,831 to 16,845 of 41609
  1. #16831
    EFI RS125
    "Second start up of the Cougar Red Honda RS 125 GP bike.
    New Ignijet 2008 ECU and wiring loom by myself. 3 injectors.
    YES THIS IS FUEL INJECTED!!! Also running Bio fuel E85.
    Lots more set up on the dyno. But initial runs look promising.
    This project has been on going for many years. From the carburated version way back in 2008.
    Stood dormant for nearly 2 years after hitting a brick wall with the previous ECU the guys decided it was time was to finish it off.
    I suggested the Ignijet ECU and away it went.
    For more information about the machine and its past:- www.cougarred.com "
  2. #16832
    OEM tuners on tps go like... 0 4 6 8 10 12 18 25 35 50 60 70 80 (roughly). When you start getting over 33% tps the throttle blade open area doesn't change as drastically. Google Honda PGM CRF tuner and view pics. I'm sure you'll find the tps % they use.Probably a good start point
    Thanks, I will follow that up, not being much interested in slow running I had mine virtually the other way around, turned out to be a mistake.
  3. #16833
    frits if you happen to talk with jan tell him thnx. some of what he did im gonna use in my engine . its not the easiest thing adding extra ports that were never intended to be there but in the end i think it will have nearly 2x more power
  4. #16834
  5. #16835
    Regarding the crank balance, what a beautiful explanation! Now I sort of understand.
    Thanks Senso. You may want to re-read it because I just re-wrote it, hopefully improving a bit on my explanation: http://www.kiwibiker.co.nz/forums/sh...post1130833843
  6. #16836
    Frits, out of interest, what alloy did you get your cylinders cast / sintered in?
  7. #16837
    AlSi12
    The page at www.kiwibiker.co.nz says:
    The messager you have entered is too short. Please lengthen your
    message to at least 10 characters.
    Now what else could we put into the alloy in order to lengthen its name without influencing its properties?
  8. #16838
    Chilli. Makes everything taste better.
  9. #16839
    AlSi12
    Thank you. Similar ish ( silicon content ) to LM13, then that is what I will use, as I have a stack of it.
  10. #16840
    21st August 2014 - 13:28
    2001, Honda, RS125
    Melbourne, Australia
    Sorry to bother everyone.
    My forum participation is too low to send privet messages.
    These dimensions for a Honda RS125. are they standard or kit?
    If Frits is going to answer (simple yes or no). here are some responses to copy and paste:
    Yes, they are Kit
    No, they are standard
  11. #16841
    I remember the problem, but it hasn't bothered me lately .
    First they were works Honda NSR250, then they became Honda RS250 kit and RS125 kit, then they became standard.
    Then they appeared on the works reed valve Derbi 125 (tuned by Harald Bartol). Then they appeared on the 125 and 250 cc works KTMs (tuned by Bartol).
    Then they appeared on the KTM production racers.
    Then Dorna & Honda killed two-stroke GP-racing, so the 250-twins could not make the 600 cc sixteen-valvers look ridiculous and the 125-singles could not do the same to the 250 cc four-valvers.
Name:	KTM GP125-03.jpg
ID:	309357 Click image for larger version.
  12. #16842
    14th June 2009 - 15:13
    suzuki
    europe
    From this table, LM6 would appear to be the closest equivalent.
    http://www.cast-alloys.com/products/lm_chart.htm
  13. #16843
    The difference between LM6 and LM13 that struck my eye was the Cu content. Better check with you nikasil-provider whether that's acceptable, Neil.
  14. #16844
    Thats really interesting. I have been looking at RS250 pipes for my NSR300. They seam to be the go to for so many 125's and 250's. A timely post. I am pulling the 300 down soon to give it a top end freshen up and (TRY) to make some pipes. I will post some pic's as I get going.
  15. #16845
    2nd April 2012 - 00:54
    eek
    Great Quote Frits.
    Deep down real 2 stroke enthusiasts will prevail
