Page 1192 of 2776 FirstFirst ... 1926921092114211821190119111921193119412021242129216922192 ... LastLast
Results 17,866 to 17,880 of 41631
  1. #17866
    soooo no time frame on a green light yet?
    Maybe, maybe not, I haven't go a clue. I've always tried to keep away from legal mumbo-jumbo as much as possible.
  2. #17867
    Neil, have a look at this. I can see quite a bit of you in this. https://www.youtube.com/watch?v=fKMLYFVwNVg There are bigger ones as well.
    The German V1 Doodlebug had steel reed valves; the pulse jet in the video is the pure version as far as I'm concerned: valveless, just gas dynamics.
    I once sketched a reed valve version for a neighbour and lent him a 34 mm Mikuni carb to help him on his way.
    The noise was incredible and so was the length of the emerging flame: he almost reduced his parents' shed to ashes. Oh well, the things you do when you're young...
  3. #17868
    Noise and flames....great.
    Frits, next year the newly homologated KZ engines will be released (I think). I was thinking about the Modena and as to whether it may get in. The rules are pretty tight it seems, and in various translations, confusing.
    As an alternative to the 24/7 mechanism, what about using spring steel reeds (as opposed to stainless) and use electromagnets in the housing that were capable of lifting and holding the petals out? Always the concerns of metal reeds breaking off and being ingested, but maybe over a certain rpm they can be held open, thereby reducing fatigue failure issues.
  4. #17869
    Yer, pistons are so last century, who needs them.
    Would you prefer jet propulsion? Better make sure that you're on pole position at each traffic light then, or you'll receive a free haircut, shave and eyebrow removal .
    Eventually we'll all go electric. But not quite yet. Storing the necessary energy directly in batteries will require a breakthrough in battery technology that I cannot see happening any time soon, so I think the fuel cell will be the way to go.
    My sarcastic view: "Hydrogen is the fuel of the future and it will probably remain so forever". Not only because of the lacking hydrogen distribution infrastructure, but also because of the huge storage problem. Even if you do not use your future vehicle at all after after filling the hydrogen tank, it will be half empty again in two weeks time because the hydrogen molecules are so small that they escape right through the walls of the tank; neither steel, carbon or rubber can keep the H2 in.
    I think the most practical approach will be to fill the tank with a liquid hydrocarbon fuel like we do now, use an on-board reformer to extract the hydrogen from this fuel, and feed it into a fuel cell. There will be losses, but the efficiency will still be much better than that of a combustion engine. And the complete infrastructure is already here.
  5. #17870
    The international kart governing body FIA-CIK considers electrickery a thing of the devil; they do not even allow variable ignition or electric power valves and power jets. And I'm convinced that they will find a way to block the 24/7 Modena even though the valves are purely mechanically operated.
    Modena and the CIK don't exactly see eye to eye; after Modena introduced its synthetic flow-guiding inlet insert, the other kart engine manufacturers conspired and the CIK announced that the insert would not be accepted again at the next homologation round, although it's just a piece of plastic that every manufacturer could make at next to no cost. In fact it was initially developed by Modena so the complex milling of the transition from the reed cavity to the transfers could be skipped. My suggestion to use a plastic with low thermal conductivity also contributed a bit to engine power.
  6. #17871
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    Major Save.
    Epic.
  7. #17872
    I think a p2 ignitech with fairly minor software changes could handle the 30k ignition, just have the CPU alternate the input pulses to the 2internal cdi's the problem isn't the speed of the input pulses just the time it takes to charge the capacitor in the cdi .this way it will act like a 15000 ignition
  8. #17873
    Studs are better. If you tighten a head bolt, you generate a tension force in the bolt and a rubbing movement between the male and female threads at the same time. Especially the female thread in the light-alloy cylinder body doesn't like that.
    If you use studs, tightening the nuts will put the same tension force in the studs, but at this stage there is no movement between the male thread of the studs and the female thread in the cylinder body any more, so no wear.
    thnx frits. thats what i was thinking also. with bolts my routine is tighten in increment steps and that would obviously put twisting tension on the cylinder threads at each step of the tightening process, which im trying to avoid. studs would eliminate that.
    i kept a IR gun close by and tried to keep the heat as low as possible but since im a novice welder at best, im sure i heated it a bit more than need be but its a learning process. still the gun never measured much over 400F even moments after shutting down the arc. will have a bottle of 75% argon and 25% helium tomorow to try. i hear the helium mix helps with cast aluminum
  9. #17874
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    I used to spin tiny valve-less pulse jets up from copper tube. Had to make quite a few before I got them so they would firstly light up and then remain stable. Unfortunately the end result was a heat profile that meant the combustion chamber was hot enough to remain annealed, but the exhaust work hardened and split in a remarkably short time.
    Darwin had it all wrong.
  10. #17875
    Come on, more wild speculation on Ryger please. Anyone? Husa is doing his fair share
  11. #17876
    27th January 2011 - 11:30
    asdasd
    AKL
    Athena EFI 2T
    Here's one for you TZ, now we just need someone to translate the hieroglyphics
    Athena EFI 2T article
Name:	Athena EFI 2T.JPG
  12. #17877
    Meh, we're done with the Ryger. What if we replaced the steel reed valves on the jet with high temp carbon fibre, bent the reed stops back and polished the insides with some of that porting paste they used to advertise in 80s dirt bike magazines? Then we could get it going real fast and burn sheds down quicker.
  13. #17878
    We aim to please:
    http://www.athenaparts.com/eng/blog/...ustion-control
    http://www.google.nl/webhp?sourceid=...=athena%20dicc
    I also have a nice PDF on the subject but I can't see a way to attach it here.
Name:	Athena-GET injectie.jpg
  14. #17879
    You're a taskmaster Flettner! Yep, it'd be good to get this sorted before the patent comes out. Sort of Southern Hemisphere vs North. Then you can go and make one.
    Frits, would it be fair to say the piston reciprocating weight be more than the piston it is replacing? This would mean the piston in its entirety, including any form of rigidly connected piston rod or tube.
    That's it for today.
  15. #17880
    We aim to please:
    That looks a lot like the Stuff HGT was selling? anyone........
    I posted a pic for Neil to build the other day and frankly I am a bit surprised he hasn't got the working prototype functional yet.............
