Page 1206 of 2776 FirstFirst ... 2067061106115611961204120512061207120812161256130617062206 ... LastLast
Results 18,076 to 18,090 of 41630
  1. #18076
    Frits, I guess you are right, there is more to this discovery than we might think. If this is what I think it is, then there will also be some VERY interested fourstroke customers, ones that might race in GP class! I can see why you NEED to keep a lid on it.
  2. #18077
    tease......
  3. #18078
    Rob will forgive me for saying (i hope) that at times he is a little keen to try to many things.
    Youthful over exuberance i guess.
    Attachment 312774 Youthful over exuberance ..... too right, or something!!!
    That bloody quote was over threes years ago.
    I am a slow reader too, just catching up ...
  4. #18079
    engmod2t
    Got an update from Neels, now turbulent works fine.
    Newb question:
    When using the numbers I got from turbulent, can I play around with ignition timing in prescribed mode, or do I have to run turbulent again everytime I change timing for a rpm point?
  5. #18080
    No, once you have saved and imported the turbulent combustion model, you can use that with changed timing numbers, saving it as a new file each time.
  6. #18081
    13th April 2009 - 22:30
    Maico Bimota 250
    You are correct, just as well I checked. Brain fade.
    After a bit of fiddling I made some improvement.
    http://www.marshland.co.nz
  7. #18082
    What about the peak and overev power - the main/corrector system can hves just as much effect there as in the mid.
  8. #18083
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    Poor man's angle porting tool;Thought you all might try making one for small cylinders,
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  9. #18084
    That is clever..... . I like it.
  10. #18085
    Only a part of the rev range shown. The whole range including overrev will show the total effect of the changes.
  11. #18086
    Maico Bimota 250
    Very nice.I'll put that on my todo list.
  12. #18087
    Maico Bimota 250
    I need to get my O2 sensor working consistently to do the top end. I was basically just trying to get the bottom end better as the 5 speed MX gearbox is not the best for the track.
    My EGT only shows 950 at max power on the track so I still have some work to do. I'm hope the EGT is correct ? Ashburton's dyno shows close to 12.5:1 fuel air so I'm not sure why the temp is so low.
    Maybe I need to do a bench calibration of the sensor and GPX Pro box. .
  13. #18088
    Clever - now put an adjustable stop on the downtube which would bear on one end of the cylinder so as to cut to an exact port height.
  14. #18089
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Love it!
    Good idea!
  15. #18090
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Is that an old Kawasaki cylinder?
There are currently 201 users browsing this thread. (0 members and 201 guests)
