Page 1215 of 2774 FirstFirst ... 2157151115116512051213121412151216121712251265131517152215 ... LastLast
Results 18,211 to 18,225 of 41610
  1. #18211
    frits your a great help but i dont understand your 8.1% corner radius. i only know radiuses in mm.
    tz350 what is a damn ? is it just a term for filling in the exh floor like me and wobbly are doing ?
  2. #18212
    I am defiantly going to include in my next motor.
    The word " Definitely" may be a better choice to use in this phrase ??
    You may wish to be careful on a single ex port engine. As Frits says if the blowdown is not sufficient the pressure will abuse the transfers as make shift exhaust ports. This will still happen but if you seriously raised the port floor to the transfer level it would be worse. But that's an extreme case of course.
  3. #18213
    Well, i've met both you and Rob. Defiantly works for either of you...Didn't you tell me you had enough Benelli barrels to keep you happy playing for years ?
    tried doing a triple exhaust in one yet ?
  4. #18214
    Quote Originally Posted by grumph View Post
    well, i've met both you and rob. Defiantly works for either of you...
    ................. true, well I hope so anyway.
  5. #18215
ID:	313074Click image for larger version.
    tz350 what is a dam? is it just a term for filling in the exh floor like me and wobbly are doing ?
    I am not sure what the proper name is or even if there is one but I called it a dam because it seems to work by reducing short circuiting from the transfers and damming the flow of incoming fresh air/fuel charge preventing it looping over and easily flowing out of the exhaust port. Just like a dam on a river.
  6. #18216
    It's 8.1% of the cylinder bore, like all the other percentages in that drawing.
Name:	FOS port shape concept.gif
  7. #18217
    Jan raised the Aprilia port floor at the duct entry 2mm ( on a 54.5 stroke ) above BDC I believe, and the bottom corner rads were
    made progressively bigger and bigger to reduce the duct volume.
    This is dyno proven ( his and mine ) to make better power, so go there straight away, but as you say dont reduce the blowdown width
    of the main port above TRO.
    Testing the reduced duct area at the port, and reducing/varying the area at the duct exit is easily optimized in EngMod, except of course as its not a 3D FEA flow code
    like Fluent etc it cant verify the effect on power of reducing short circuiting.
    Jan tested everything and 25* was best.
    RSA ex port
    The exhaust port isn't canted downward 30°. The flange mounting face is canted downward 30° but the roof of the exhaust duct exits the cylinder at 25°.
    The reason is that this angle gives the best flow. Frits I think?
    The cylinder I have also has its exhaust port above bdc by about 2mm.
    But I would suggest the bottom of the exhaust port has a distinct curvature near the outlet.
  8. #18218
    RSA ex port: The exhaust port isn't canted downward 30°. The flange mounting face is canted downward 30° but the roof of the exhaust duct exits the cylinder at 25°.
    Frits I think?
    Guilty, your Honour.
  9. #18219
    ok any ideas what this cylinder is it was in my Aprilia pics but it doesn't look in place.
Name:	any ideas.jpg
  10. #18220
    Provisions for coolant hose pillars left and right; could be a kart cylinder (they all copied Aprilia).
  11. #18221
    25th June 2015 - 21:46
    NewZealabd
    TF125 engine mods
    I would like to give the good old Suzuki TF125 engine a wake up, can anyone give info about port measurements? also need to use factory carb so any idea on jet sizes after the port work? Or any other idea to wake her up?
  12. #18222
    Report from northern hemisphere.
Name:	Ryger cop out.JPG
ID:	313088Click image for larger version.
Name:	Here a FOS, there a FOS.JPG
  13. #18223
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    Quote Originally Posted by mudbugracer View Post
    This whole thread is about giving 2T engines a wake up.
Name:	Degree Wheel.jpg
    And your best friend will be a degree wheel like this one made by gluing a paper printout onto piece of sheet metal another easy way is to buy a large protractor from a stationary shop.
  14. #18224
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    sorry they only put things to sleep in here lol
  15. #18225
    Ha Ha ha. What, didn't they like you telling them we know what was inside?
    A little wind up never hurt.
