Wobbly, can I ask your advice please.
You'll remember that senso posted photos of his CRM50 cylinder that he cut up to see how close the water jacket was to the ports (see photo).
I also have one of these engines, which I've started modifying.
Upon measuring the exhaust port, I find that the narrow bit you see in the photo has an area only 73% of the standard port area. Obviously that will be worse when I increase the port area.
I plan to make an insert to reduce the flange area as you suggested to senso.
My question is: Should I try and make this restriction equal in area to the port, or could I begin the 90% area from this point out to the flange?
My immediate question is to establish if the restriction is 73% of the EFFECTIVE port area ie The measured port area X the Cosine of the down angle.
And subsequently the answer is that the duct should be as smoothly transitioned down to 90% at the exit as is possible.
You cant use ally plates in a dry clutch - they warp instantly from heat stress.
One last question please Wobbly. The insert I make for the cast-iron CRM50 cylinder: Can it be just mild steel? Is Aluminium alloy an option?
If neither is good, can you advise what is?
Sorry, that's 4 questions. Never could count...
Even these ones ? http://www.thetuningworks.co.uk/stor...oducts_id=1159
Yea, well as the advert says Standard VJ22 clutch. not SP or F3 ie they are for an oil bath.
I have tried Hinson cryo'd plates for Banshee in a TZ350 and they were fucked the first hard start thrashing they got.
Re the insert of the Ex duct - make it in ally and give it a real heavy press fit to help the heat transfer path
There are currently 172 users browsing this thread. (0 members and 172 guests)
