Page 1228 of 2776 FirstFirst ... 2287281128117812181226122712281229123012381278132817282228 ... LastLast
Results 18,406 to 18,420 of 41630
  1. #18406
    unfortunatly i reside in the land of yanks but want no part of their ' in doubt bore it out mentality'. for pete sake theyre still using 115 rods on 64mm crankshafts. dont bother trying to tell them any different as they wont hear of it
    anyways on to something worth talking about. pretty sure it was frits who posted this some time ago. does anyone know something about it ? looks like a great idea but why dont we here more about it http://www.zeroshift.com/
  2. #18407
    What size is that KTM again?
  3. #18408
    i reduced the bore 3mm and lengthened the conrod 4mm . far as i know theres no longer conrods available to the public
  4. #18409
    Kawasaki KX500 is a tad longer and I think the Husky rod is longer again, assuming you are using the CR500 rod.
    It still started life as a KTM550.
  5. #18410
    Quote Originally Posted by husiberg View Post
    That Bud Aksland did all right, surprised you forgot about him Dave.
    Attachment 313570
    Center of the Pic, propping up Kenny Roberts.
    Attachment 313571
    I thought i did by association. Evil Empire being Kennys crew.
  6. #18411
    Isn't that HONDA crowd normally the evil empire.
  7. #18412
    That was later but for a while Kenny's team had all the best riders and most cancer stick money, biggest transporters etc hence the pit moniker. Or so the magazines put it. I of course wasn't there.
  8. #18413
    frits maybe im wrong on this but isnt the port timing of a modern 2t engine mostly useless numbers as its only the point where the window opens and closes relative to crankshaft degrees with no regard to time area or angle area ? you could have a tall window and still a small angle area.
    If the timing of a port would be a useless number, then so would be the port width, wouldn't it? I'd say neither is useless, but only together are they meaningful.
    was there ever a usa 2t racing team worth mentioning ? it seems as if the usa tuners are 100 miles behind the rest of the worlds tuners. advancements in recent 2t development dont seem to be associated in any way with usa. im trying to think of one thing they could take credit for. even with some fairly modern designs like ktm to look at, they seem oblivious to the fact they could apply some of those ideas to older engines. maybe they like being stuck in 1980 with short rods, over sqaure pistons and small crankcases
    There are quite a few capable two-stroke specialists in the USA but their names are not generally well-known, as opposed to the 1970s and 80s when we had Erv Kanemoto (100% American in spite of his oriental-sounding name), Kevin Cameron (still a highly appreciated technical editor), Don Vesco, Bob Work, Kell Carruthers (originally an Aussie who became chief whip in Kenny Roberts' team after having been a 250 cc world champion himself), Bud Aksland, and many others.
  9. #18414
    13th September 2014 - 05:14
    '76 RD-400C
    The Emerald City
    So sorry for you . . .
  10. #18415
    17th September 2013 - 01:07
    SWE
    I've not used that method personally but I'd guess that better control of just where you're heating and a cleaner working area would make it better overall.
    Better than oxy acetylene at least...
    Thanks Grumph!
  11. #18416
    There are some very good US 2T tuners like not that well known like Eric Gorr, then there are the slippery "salesman" types like Pro Circuits Mitch Payten, who still knife edges transfer dividers and charges as much as a small family car.
    Erv Kanemoto was as good with frames and fabrication as he was with tuning engines.
  12. #18417
    yes 1mm but if i recall it has a odd wristpin at 19mm where as the honda is 20mm and it just so happens the honda piston fits right in the 500 ktm cylinder. the last husky 500 i know of was around 1987 or so. parts must be rare as hens teeth by now.
    it may have started there but it ended somewhere else . the aux exh ports poped open under the piston at tdc, the rod and piston were very short, case ratio around 1.5:1 from what i remember. i dont know why anyone would bother with those headaches
    back to the 'when in doubt bore it out' theme for a moment. those same yanks might be the only folks selecting fuels based on static cylinder pressure. i thought about it a few times and couldnt find any connection between fuel type and cylinder pressure at 300rpm. last i heard, compression gauges were used when buying second hand cars
    2T institute, most everyone over here is still knife edging all the dividers, yes even the yamaha twin cylinders. dont ask me why as i have no answer
  13. #18418
    Angle areas are not the limiting factor in a two stroke. Friction is.
  14. #18419
    Ahh well you need to use Amsoil
    (1200 pages & I'm going to crash it now by turning it into the dreaded oil thread)
    Here come the zealots, run!!
  15. #18420
    Here is me thinking it would be thermodynamics or physics.
There are currently 147 users browsing this thread. (0 members and 147 guests)
