Page 1236 of 2776 FirstFirst ... 2367361136118612261234123512361237123812461286133617362236 ... LastLast
Results 18,526 to 18,540 of 41629
  1. #18526
    It may be just my suspicious mind, but do I feel a hand on my leg again?
    Frits, don't worry, you're safe
  2. #18527
    Wobbly/Frits , after combustion of the fuel in the two stroke cycle, the gases produced expand and force the piston back down the cylinder... this explosion causes a pressure wave . is the pressure wave a different thing to the expanding gas pressure? if the blowdown is not enough to allow the pressure in the cylinder to drop below that of the transfer ports , is it the gasses pressure or the pressure wave which causes the stalling of the transfer flow. if they are two different things, what happens to the pressure wave if some of it disappears down the transfer ports
  3. #18528
    I happened to notice this addition to your original post, Neil. Normally I would have missed it. And I hate missing things, so from my point of view it would have been safer to put it in a new post instead of adding it to a post that I already thought I'd seen. Come to think of it: God knows how many valuable additions I've already missed because I usually don't go back to 'old' posts.
    That Husqvarna video of yours reminds me of a Stihl patent ( http://www.google.com/patents/US6415...roke+OR+engine ) wherein scavenging is also taken care of by air only, after which the fuel-air mixture is transferred. But I don't see any similarities with the Ryger engine.
    Ok, thank you.
  4. #18529
    I know its only semantics but we may as well get it right.
    Its not "after " combustion, its as soon as the initial kernel of ionized molecules starts to consume the trapped A/F mixture
    that the pressure begins to rise due to the increase in temperature.
    Remember PV=nrT, the V varies only with piston movement thus P is proportional to T ( n&r being gas constants ).
    We DONT have any " explosions " at all in this process, only fuel and oxygen being converted into pressure.
    There is a moving wave front within the combustion space as the burning mixture expands out from the plug gap in the center, but pressure by definition is equal in all directions
    and a wave must have a vector to define its direction.
    When the transfers open, and if due to the design intent, or a lack of design knowledge , we have excess pressure above the port over that
    within the duct, then reverse flow into the duct occurs.
    This initial reverse flow can, and if you are clever usually is ,used to affect the scavenging pattern within the rising gas column ( Frits leaning tower from Italian parts )
    by delaying the bulk flow from the transfer that opens first.
    This effect as a general rule works to enhance midrange power if the A port opens first, or enhances peak and overev power if the B port opens first.
    So this answers the question often asked re is it possible to have too much blowdown STA - no its not in a full race setup,but its very possible in lower power scenarios
    and if it occurs then we have no reverse flow having a positive affect on the scavenging.
    There is 20 more pages of detail, but even this is too long.
  5. #18530
    2nd April 2012 - 00:54
    Wobbly would you PM me the 20 pages. Sounds like a good read 😃
  6. #18531
    That's all I can say right now.
    Here is some questions you can answer Frits.
ID:	313722Click image for larger version.
ID:	313723Click image for larger version.
ID:	313724Click image for larger version.
ID:	313725Click image for larger version.
    I had heard of a Swissauto/Roc powered mock up. is this it?
  7. #18532
    This is a genuine Aprilia 500-V4 Grand Prix racer. That means: it was built in the Aprilia Racing Department with the intention of replacing the RSV500 twin.
    But the V-4 never appeared in an actual GP. The engine was from Swissauto (very compact, but with a horrible welded-up crankshaft and a terrible vibration).
    I don't recall if the frame was Italian-made or brought in from the French ROC company that built 500 cc production racers based on Yamaha V-4 engines.
    A couple more pictures of the bike:
Name:	Aprilia 500-4 00.jpg
ID:	313727 Click image for larger version.
Name:	Aprilia 500-4 04.jpg
  8. #18533
    Thanks Frits I would say to my untrained eye the chassis it looks very ROC like.
ID:	313729Click image for larger version.
ID:	313733Click image for larger version.
    Wobbly does it look like the same as the Pulse 500 Frame?
ID:	313731Click image for larger version.
  9. #18534
    I'd say you're right Husa. Here are some more pictures of the various bikes that have been built around the Swissauto engine:
    http://www.google.de/imgres?imgurl=h...IVQRQsCh2L1QuF
  10. #18535
    Wobbly thanks for reply... .
  11. #18536
    detonation
    wobbly, detonation is a destructive force?... is that only because the materials used in pistons and cylinder heads spark plugs cant withstand its actions. if they could, would inducing detonation produce more heat... pressure, than combustion?
  12. #18537
    7th June 2009 - 13:29
    Norton Manx
    Over the Rainbow
    Here is a Thought Experiment. re combustion vis explosion.
    Given that they both give off the same amount of total energy.
    On a cold evening which would you rather sit in front of:- a nice warm open fire or an exploding stick of dynamite.
    Pressure is the product of the combustion heating the gases in the combustion space and the amount of heat energy is dependent on the fuel. Burn more fuel in a given time and you get more power.
    So my guess is that the end result between combustion and explosion for the same amount of fuel is the same amount of heat induced pressure but the speed of the pressure rise between the two is dramatically different.
    Same total energy but one gives a sliding action because its applied over a longer period of time the other is an abrupt hammering action that overloads components.
    Anyway that is how I understand it and it would be interesting to hear more about this.
  13. #18538
    Here is some other pics the Website missed.
    http://www.kiwibiker.co.nz/forums/al...p?albumid=4833
    When you said the crank was welded that confused me. Where was it welded
    I remember Wob saying it was a bloody expensive crank.
  14. #18539
    The Pulse chassis was built by the Roberts Team in England around the SA engine,I could find out easy enough if one was sent to Aprilia
    either by Dave ( thieving bastard ) Stewart recouping cash or if another of the chassis was copied and sold to them by by Roberts.
    Re the power potential as you approach det conditions.
    As I said there is a finite energy load in each combustion event and its easy enough in a 2T to dramatically redistribute where this energy goes.
    Crank up the timing or the com and more heat goes into the piston/head/water, and less remains to activate the pipe wave action.
    But deto is a completely different animal.
    The excessive heat in the combustion space and the resultant shock wave moving uncontrolled thru the burning mixture destroys the all important boundary layer
    that protects the piston and the squish band head material.
    Thus the end gases erupt,creating more heat,and this gas trapped in the squish is so violently consumed due to the spastic levels of turbulence,that free radicals begin to form.
    Once this starts,huge amounts of the available energy is used to create even more free radicals - a thermonuclear reaction in reverse.
    These radicals are highly chemically reactive, and it is this property that eats away the alloy piston/head giving the classic deto signs around the bore periphery.
    Using up huge amounts of the combustion energy like this of course means less is used to give the pressure rise,pushing down the piston - but also less heat
    escapes into the pipe.
    Thus the instant deto is forming the egt drops, and NO its not lean, its about to explode - literally.
    Result - power craps out big time, but as is human nature,when det counters became available the rule of thumb that gave best performance was to have 3 det
    "events" per Km.
    All this meant was that the tuning was being pushed right to the edge by monitoring the amount of deto happening.
    Made for lazy tuners that never learned how to read a plug accurately - just read a gauge.
  15. #18540
    23rd February 2010 - 18:49
    As many as I can get away with
    By welded up crank he probably means that the crankpins are tig welded to the crank webs (flywheels) so that the crank doesn't go out of phase. I did that to the 90 degree crank I made for my Matchless sidecar. It stops the "push" from one cylinder from turning the web on the crankpins, as the push is phased and hence not equal or at least not at the same time or 180 degrees apart. The weld only needs to be very small (not all the way around the crankpin) to ensure the pins don't turn.
There are currently 137 users browsing this thread. (2 members and 135 guests)
  1. crbbt,
  2. Peter1962
