Page 1238 of 2776 FirstFirst ... 2387381138118812281236123712381239124012481288133817382238 ... LastLast
Results 18,556 to 18,570 of 41630
  1. #18556
    Excuse my ignorance but why do many of the 2 stroke cranks I see appear to have a cover on the web? Such as the crank above.
    Because it's the cheapo solution. The crankshaft shown in my previous post is from the Honda RS250 production racer. The crank webs are forgings with the material distributed correctly for balancing. But that would leave a clobbered external shape, so a tin cover is pressed around the lot.
    The crankshaft below is from the NSR500. That was a works racer; no tins there...
Name:	Honda NSR500-1978-04.jpg
  2. #18557
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Quote Originally Posted by gravmax88 View Post
    RGV250 cranks come with the center section welded from the Suzuki factory..............
    not case harden there then
  3. #18558
    23rd February 2010 - 18:49
    As many as I can get away with
    That is exactly right Swarfie. I've seen welds where the crank pins were pressed into the flying webs (B), and in some cases also where they were pressed into the outer webs (A). The Hirth joints that made the Swissauto crank so expensive, were not welded.
    Attachment 313745
    Thanks Frits....I only welded my crank at A in your diagram (only a twin cylinder engine), as I had had a crank years ago turn/move (and subsequently go out of true on the output shaft) that I had made out of two TT500 Yamaha cranks for a mates Matchless twin. I use a "Hurth" coupling of my own design which will never rotate, which is basically square holes in the centre two crank webs with a centre mainshaft with corresponding squares each side of the round centre bearing shaft. This is pressed up with only 0.02mm interference but by it's very nature can never rotate (and has never separated/moved). I'm reminded of the old saying "keep it simple stupid Interesting that I use the original Yamaha TT crankpins (on a 34 mm diameter pin) which even at an interference of the original Yamaha spec at 0.1 mm can still move/slip and is the reason I welded as a precaution more than anything else. So actually IMHO even good design can sometimes (and in the case of a sidecar where the loads are so much more than a solo) come back and bite you in the arse.
    As a side note, my "Matchless" replica engine has won the Classic sidecar trophy in NZ 17 times to date and at first attempt in Australia in 2000 took out the Ausy Championship (knocking more than 2 seconds off the classic lap record at Syney's Eastern Creak circuit in the process)....so we'll have no more of this "bad design" BS please from Mr J Quest....sour grapes...not much
  4. #18559
    I also note the hand finishing on the rods.
    Quote Originally Posted by swarfie View Post
    So the Matchless is it still three bearing plain center or roller?
  5. #18560
    Three roller bearing crank. Parallel roller in the centre and shouldered roller bearings each side for axial alignment. In fact the only bushes left in the engine are in the OHV rockers, even the cams and timing gears run on needle roller bearings. Done it all proper like....unlike the poms
    Also made my own rods after a Yamaha one broke in 2010 and wrecked things a bit. The engine makes really good torque and doesn't need to rev past 6500 but the TT rods couldn't hack the pace so made the new ones out of Assab 718. Doubt I'll have to see them for a while.
  6. #18561
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Talking cranks a question occured to me:
    with which size of press fit are Aluminium and tungsten inserts pressed in the crank?
  7. #18562
    I don't know as I haven't had to use them to get a balance factor but as there's no load on them they probably only need to be 0.01/0.02 mm press to hold them in place. I work with fits and tolerances on a daily basis for my job (toolmaker) and for like materials a size for size fit is a press fit so only having to allow for a differential in expansion would keep inserts in place.
  8. #18563
    Neville M , I assume?
  9. #18564
    You might be able to answer Tim Ey on the subject of crank stuffing plugs better than me Neil.
  10. #18565
    Yes, I've stuffed a few cranks in my time
  11. #18566
    21st March 2014 - 22:00
    Hanau, Germany
    RWHP of a V2 TZ250
    Thank's a lot Wob for the answer about the reeds, will follow that and will do some testing.
    Just an other question, does somebody can tell me if the Yamaha stated 87 HP of the mid 90th TZ250 V twins was rear wheel HP or "at the crank"?
    Juergen
  12. #18567
    Juergen
    Hello Juergen
    Like all Japanese factory hp claims it was measured at the piston ring..............
    Unfortunately due to there small size and poor sense of direction, Maybe only 73 or so of those horses where able to find there way back to the rear wheel.
  13. #18568
    Hanau, Germany
    Thank's Husa, just hoped that they did same like for the road bikes. I'm looking to push my TZR250R (the last 2 stroke for road use what Yamaha produced) to higher limits. Unfortunately it has the same worse bore / stroke ratio like the TZ's at that time (as a lot of the engine parts are exactly the same). But with all the advise from Wob and Frits my sim show up more than 80 HP on the wheel so lets see, next topic is the weld up the ex port and the spigot to finally match the correct dimensions, will report back.
    Juergen
  14. #18569
    31st July 2005 - 11:15
    a shed full of crazy shit
    Hello Juergen
    Juergen
    It will be interesting to see where you get too Juergen.
    I'd love to see 80+ from my TZ250 (not TZR); while I have a few spare TZ barrels, much rather tinker (likely destroy) some of the 3xv sp barrels (given they are not rocking horse shit).
    While you say the parts are exactly the same - there is a number of differences in the port layout and time areas.
  15. #18570
    1st March 2011 - 19:15
    1996 Buell S1
    Orewa
    BS most likely
There are currently 80 users browsing this thread. (0 members and 80 guests)
