Page 1245 of 2776 FirstFirst ... 2457451145119512351243124412451246124712551295134517452245 ... LastLast
Results 18,661 to 18,675 of 41630
  1. #18661
    All latest generations of engines with normal stagger ( A port first ) have the same axial relationships as the Aprilia.
    Flat A ports are long dead.
    Welding the roof corner is needed in the Yamaha B port to flatten it out as it goes into water, the A port simply needs epoxy
    to fill in the top radius and increase the upward tilt.
    The C port is always in the 50 to 60* range, depending upon the end use, the bore/stroke, and the port width in relation to the B width.
  2. #18662
    The crank in the photos is from a Mercury inline six, but (guessing) about fifteen years and one design-generation newer (early '70s) and with 40-50% more displacement than the red Mk78 (about 1958) in the photo. The car has a V-6 that's a good ten years newer yet. If you're into this old stuff, the last generation of crossflow Mercs was called "Direct-Charge;" google that term for photos of the somewhat unusual piston.
    On Pg. 78 of The Bucket Foundry thread is some talk about an oddball outboard project; Flettner, I think the crank you picked up might well be the one that Dick Austin is using in his homebuilt motor (which however is loop-scavenged, not crossflow).
    The rod with the beam, page 78? That's a rod, and I am using a crank from, a 250 four 4T to make an oil less twostroke. Will be using the FOS concept (sort of). It's being machined out of solid plate as I wright. Is using a "leagal" pressurised crank case.
  3. #18663
    Well what? Bets please, on what the outcome might be
    I can understand that many of you have been holding your breath, just waiting, so, to avoid any further suffocations, I am happy to say it works.
    However , working to the level of 70 hp @ 18k, it might take a tad more effort. There's some weird phenomena going on that I've gotta get my head around. But after that, I'm going for 80hp. Sorry Harry.
  4. #18664
    Ken ,any chance you could be more specific?? or are you holding yourself back because of legalities
  5. #18665
    Anyone here friends with BRC karts? I'm after one of their pistons, for the sleeve engine. 24mm crown height from the gudgin pin center.
  6. #18666
    7th December 2013 - 00:25
    Yamaha's
    Hellas
    I think epoxy is also good for inner radii!Does it work?Did you test it?
    What brand should I trust?
    Cheers
  7. #18667
    I think I got something here. Remember, the RSA had a carburetor from the garden sized 43mm and 54hp @ 13000 rpm. Then along comes the Ryger with 18000 rpm and a carburetor from the garden sized 30mm. Now in Ken's picture, guess what's there! Exactly, an even smaller carburetor from the garden! This can not be coincidence! I can not say for sure which number there is on the carb, but if it's anywhere near the 19 I think I could decipher on that carb, then this thing should have the potential for triple digits, for sure!
  8. #18668
    try rick he is spanering Superkarts with a Aprilia clone DEA?
    Hello all, great forum, great to see a bunch of enthusiest sharing ideas, knowledge & encourigement
    My question, can anyone assist with the direction to the page where Frits Overmars mentioned, fuel pump type / site link, pressure ect upon the Aprillia
    Cheers all, keep up the great sharing of a common interest, Without competers we all LOOSE
  9. #18669
    Neil, the man to talk to at BRC engineering is Riley Will: http://www.brcenginc.com/contact.html
    Other possibilities are
    Andrea degli Esposti of DEA, deaengineering@gmail.com
    and
    Francis Payart of FPE, f.p.e@wanadoo.fr.
    You can give those guys my regards, and they may still help you .
    Francis is even a kiwibiker forum member, so you could send him a PM, but I don't know how often he takes a look here.
    24 mm from gudgeon pin center to tip sounds familiar. The Aprilia RSA and RSW had either 24 mm or 21 mm.
    Try Asso and Vertex in Italy; both of them supplied the Aprilia racing pistons.
  10. #18670
    wobbly you ever tried this stuff ? i got some the other day as i figure now the cylinder is located 6mm higher and wider sides with the pieces i welded over the water jackets it puts the head and cylinder much closer to the fuel tank underside. a heat barier on the fuel tank bottom couldnt hurt i guess
    http://www.ebay.com/itm/DEI-010396-2...27c1fc&vxp=mtr
  11. #18671
    and
    Thank you, again.
    The sleeve engine has been sitting waiting for me to build a piston, so I decided to build a blank and see what was required (no drawings, the engine just evolves as I go), to my good fortune it would seem I can use a ready made piston (as above request) but just modified a bit. This has put the sleeve engine "back on the burner" as it were.
    This is NOT the oil less engine as this sleeve engine will consume a lot of oil I think (like the Crecy).
  12. #18672
    For smaller jobs J B Weld is a great epoxy for ports.
    Better for bigger filling jobs is Devcon F.
    I have used the same type of reflective tape around kart fuel tanks, and airboxes to stop heat buildup - seems to work fine but have
    not used the gold stuff before.
  13. #18673
    Thank you, again.
    Piston pour TM K7 e Vortex, TM 10050
    not quite
    http://www.superkart.it/index.php?ma...x&cPath=92_108
    these I think might be 25mm
    you will gain the rest offset boring the pin housing
    http://www.ebay.com/itm/otk-tony-rac...-/252037482178
    http://www.ebay.com/itm/go-kart-vert...item3a9f90b4bf
  14. #18674
    Still searching for a 38PWK - anyone
    Think I found one, Wob if you are still looking for one and if this is what you want, PM me.
Name:	38mm PWK 001.JPG
ID:	313987Click image for larger version.
Name:	38mm PWK 005.JPG
ID:	313988Click image for larger version.
Name:	38mm PWK 006.JPG
  15. #18675
    i think this is the same stuff jan used. it works pretty good and cheap as peanuts. consistency is like putty so you can do alot of build up http://www.ebay.com/itm/Green-Stuff-...item19cbff5d2b
There are currently 47 users browsing this thread. (1 members and 46 guests)
  1. Mike Fisher
