Page 1261 of 2774 FirstFirst ... 2617611161121112511259126012611262126312711311136117612261 ... LastLast
Results 18,901 to 18,915 of 41608
  1. #18901
    I always thought I was invisible............Have a look at the top of the page Mike
    I wish I was invisible, what sort of shit do you get up to?
    To my credit I spelled it differently
  2. #18902
    Kaaden unsuccessfully tried ringless pistons. But his access to metallurgy was known to be poorer than the Japanese or Europeans. yet the Japanese and Euros never went this route either.
    Your post there got me thinking about how one some of the tiny aero engines have no rings Secondly if anyone had ever tried a piston design with a Lab type combustion seal arranged of multiple grooved pockets.
    Maybe with a better guided piston ring friction and the breaking of seal with tilting is not an issue and design can be different
    I do however thing the limiting factor of high speeds breathing limitations was due to blowdown rather than total port area of the EX port. So it might be moot.
    Imagine the blow down (time area) on a three port exhaust with no bridges, ie just one large hole, plenty of blowdown area.
  3. #18903
    Taking out the bridges I don't think would add significant area well not enough for 30000 rpm anyway. Something more at play in the Ryger.
  4. #18904
    Gas flow past bridges (surface area) will signifcantly slow down.
    I remember some years ago reading about the CR 250 1974? having a lot more exhaust area but because of the bridge, in fact flowed less gas than the YZ 250 ( single port).
    But you are right there is more going on in the Ryger than this.
  5. #18905
    I am not convinced as the cylinder pressure at blowndown is bloody high. look at how the gases are able to escape those poppet valve curios.
    Sure total gas flow will be higher but I don't think that is as much of an issue as the blow down time area.
    I am still on the theory they have brought more time with higher delivery pressure of the transfers and or dwelling
  6. #18906
    18th July 2015 - 16:21
    2015 Avanti
    I never did try the raised bottom exhaust port, but have seen it done. On the smaller engines it is too hard to tell if it really is and advantage or not.
    But one thing I have seen is when the bottom corner of the exhaust was made as a big radius with a 30 deg chamfer slope towards the center. That had a very big negative effect on the engine's performance compared to the 1/16 corner radius and a flat bottomed exhaust. It was done initially as a means of making sure there could not be any sub piston induction. I will have to try the raised floor though and see what the effects are with the smaller engines.
    Some one mentioned about labyrinth ring grooves on a piston. These have bee tried by lots of modelers with varying success, but the reality on the model engines is if the surface finish is right to start with and the amount of taper to compensate for the liners growth with the heat. With a properly
    made piston and liner surface finish, adding the labyrinth grooves does not make the engine produce any more power or add to the longevity of the sealing ability of the assembly. Better metallurgy was the key for the success of the ringless high performance model engines. With more time and development, I am sure that there could be a combination that could work with bigger piston sizes like those closer to 40mm or 50mm diameter.
    A lot of current small engines are using RSP444 which has about 30% silicon in it and is very low expansion material. The trick will be to find a liner material that matches that expansion rate.
    Sometimes small changes can have a substantial effect, it is just a matter of finding the combinations that work the best.
    Neil
  7. #18907
    You want a liner that matches the piston's expansion, but not its expansion rate. That would only make sense if the liner became as hot as the piston, which in turn would mean that the piston could no longer transfer its heat to the liner, which would mean the piston would get hotter than the liner: Catch22.
  8. #18908
    On the bridged port NiCasil MX engines I still occasionally do, I send cylinder off with no port chamfering... and instructions for them to not do any chamfering. I only radius top edge of ex port. All other ports I don't even touch. I believe this helps with short circuiting, and a nice consistent transfer opening. Never had a problem with rings
  9. #18909
    2015 Avanti
    Yeah , you are right Frits, bad wording on my behalf. With some model engines, they make the liners expand slightly more than the piston, so if the engine runs lean and over heats, the engine just looses seal pressure then slows down, or stops. Then if allowed to just cool, it is all fine with no damage to the piston/liner fit. The big end bearing on the rod or the crank pin may have an issue though.
    The best engines seem to show no signs of rubbing the piston on the cylinder bore,apart from the seal land area, and I have always assumed that the cooling occurred mainly due to the oil underneath in a 4s situation or the incoming air/fuel in a 2s situation.
    Neil
  10. #18910
    But then you'll be restricted to a 24mm carb, if I read the new rules correctly?
    24mm, doesn't seem to matter, Ryger 70HP on 30mm
  11. #18911
    Honda RS125 Ports as best as I can measure them:-
    (F4) (F5) Etc refers to points in the Yamaha SAE paper and can also be seen in Pic-1.
    Download the SAE paper from Yamaha on Port Shapes and Power:- http://www.2stroke-tuning.nl/media/pdfjes/porting.pdf
    Bore 54mm Stroke 54mm R1=27 (F5) R2=12.5 (F4). The Piston has a very slight dome.
    Transfer Port Opens 41.75mm-116 ATDC Inclined Up (F3) 30Deg P1=70 P2=30.
    Auxilary Type-1 (F9) Port Opens 43mm-119.5 ATDC Inclined up 15 Deg.
    Boost Port Opens 43.5mm-121 ATDC Inclined up 55 Deg.
    Pic-1 The Data, Pic-2 The Honda RS125 Ports, Pic-3 The tools for measuring the port angles, Pic-4 The very clean edges in the ports, Pic-5 The piston at BDC, Pic-6 The crankcase port windows.
    Now that I am interested in the NSR110cc water cooled engine I looked up the Honda RS port info and Yamaha SAE paper posted earlier on transfer ports. Like Wob and Frits say, the A ports are inclined up the steepest with B much shallower and C (boost port) at 55 deg. The link has pictures and link to a Yamaha SAE paper on transfer ports.
  12. #18912
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    For comparison Honda Rs Scavenge
  13. #18913
    If you look at the porting from side on you will se why it is they are arranged like this.
    The scavenge pattern is arranged to prevent short circuiting and have the rising columns colliding in such a manner that the they do not escape and are able to fill the cylinder both quickly and efficiently.
    Frits from memory did a nice piece on it around xmas 2 years ago
    http://www.kiwibiker.co.nz/forums/sh...post1130452977
    Pretty sure I have pics of a cut up Honda cylinder.
    http://www.kiwibiker.co.nz/forums/sh...post1130766509
    Plenty of RS pics here
    http://www.kiwibiker.co.nz/forums/al...id=4841&page=7
    The KTM is worth a look pretty much a Honda.
    http://www.kiwibiker.co.nz/forums/al...p?albumid=4857
    One you posted years ago
    http://www.kiwibiker.co.nz/forums/sh...post1129196083
    http://www.kiwibiker.co.nz/forums/at...6&d=1241260771
  14. #18914
    20th July 2010 - 18:11
    Mb100
    auckland
    bike wanted
    Does anyone have a bike I could ride tomorrow please for a small fee?
  15. #18915
    frits i have discovered the secret of ryger. it must use one of these gadgets http://www.ebay.com/itm/Pulse-Inject...e3c422&vxp=mtr
There are currently 81 users browsing this thread. (0 members and 81 guests)
