Kel, the usual way to remove the compression rod from the cap is to make a small clamp from two pieces of ally
with a hole drilled thru the centre line.
This holds the rod and you can then undo the locking nut to remove the fork top assy.
Peewee, I would lower the windows and make the middle as wide as the bridge, add a couple of small holes in the
piston bridge for lube as well.
good idea wob i didnt even think of that but after another look it makes sense. lower it to the floor like this should work good
104cc 30mm
for you 100/110 water guys
B port % width is a fuzz more than RSA
the inlet area is alittle small but the piston windows may help. ill check engmod to confirm however but if i position the windows low and wide, then the crankcase will have two sources to pull mixture through near bdc, as there will be piston windows and boyesen ports. i may even cut the windows alittle lower than the inlet floor so they stay below the floor even after the piston is on its way up but all this remains to be seen as i havent got that far yet. reed block seems a bit undersized but i believe the general consensus is that it self compensates by staying open longer if needed. im not real concearned as i dont feel like cutting it off and welding on a bigger one. carb is 48mm lectron , i dont have money for a bigger one so i guess it will have to do. the exh pipe may be the biggest problem as it appears to be rather long with shallow cone angles but ill sort it out when i get to that point but most likely ill probly need a new pipe if im to see top performance
Go another step, as inflow from the reeds does not happen till approaching transfer closing.
The more area down low the better, you will have to fudge the geometry in EngMod but it will work well.
Take care not to weaken the cylinder; the bottom rear part of the sleeve has been known to break off sometimes and the ears for the cylinder studs may break off too.
Remember that during the upstroke most of the fresh mixture has to go under the piston, but during the latter phase of transfer most of it has to flow from the reed upward into the transfer ducts.
In the VHM video the radiused edge piston shows a small blowdown increase: 3,2% more flow at 8° opening; 2,4% increase at 27% opening. Too bad they didn't show the difference in exhaust backflow and transfer flow. I've seen improvements of well over 10% in the closing stages of backflow and in transfer flow.
You may, my good man. Ryger had this idea long before we got acquainted so I didn't witness his day-to-day proceedings from day one, but I think the oil-less aspect was his reason to start looking for options and the power gain was a surprise. I experienced it the same way. The oil-less aspect is simple and easy to understand,
but I think I would not have foreseen the incredible power gain either. Even when I learned that it existed, it took some figuring out to find an explanation for it.
EDIT: I don't mean to suggest that the power gain was just luck. Harry Ryger has been working on his brainchild for over ten years. If memory serves, two years ago the power was 56 hp which was not too bad compared to the 54 hp of the Aprilia RSA, but as we now know, that was not the end of it, power-wise.
Talk about the devil: a couple of weeks ago I pointed Harry Ryger to the kiwibiker-forum and he seems to be impressed; I just found this mail in my in-box, with Harry's request to post it here:
Dear (two-stroke) friends,
Thank you for all the attention you have given the Ryger engine.
My name is Harry and I have been working on two-strokes for about 45 years now.
Back in the year 2000 I was convinced that a clean two-stroke would be possible and I started thinking .. five years before the idea was finally there in the middle of the night, April 2005.
Then it all started… It took me 10 years of development and it was not much of an easy ride.
Nobody believed at first and there I was.. alone with some bits and pieces building the perfect engine.
Honestly I didn’t expect it was that good, I knew it was clean but the power was a nice present that came along with it !
The reason we introduce the Ryger step by step is simple: it is not meant for the big guys but for everybody.
Upgrading a conventional two stroke must be available to everyone before it is to late because of inescapable new emission regulations.
A few things to think about :
30.000 rpm ? easy….. it could do a lot more. How ? don’t let the piston touch the rings !
Port timing ? …not important !
Crankcase volume ? not important !
At last a big thank you to my dear friends Frits, Luc, Thijs and the lot from the Ryger team !
P.S. now and then I answer some questions but within my limitations, on my facebook via pm…Mcd Twist Ryger Engine.
Kind regards
Harry Ryger
There are currently 185 users browsing this thread. (0 members and 185 guests)
