Page 1298 of 2776 FirstFirst ... 2987981198124812881296129712981299130013081348139817982298 ... LastLast
Results 19,456 to 19,470 of 41630
  1. #19456
    ... is there a requirement for a kill switch? If the Ryger is running HCCI ( auto ignition ) how the hell do you turn it off if the engine gets away on you? Assuming a stuck throttle say. Turn the fuel off and wait? Fire extinguisher up it's carby?
    Often had that problem with the acetone/methanol and a dash of nitro 2T's. The kill switch did nothing and the engine would barely slow down when the throttle was shut. The answer was to stall it and/or pull the choke on and wait till the rich mixture drowned the hot spot ignition source. Bit tricky when your diving into the hair pin at a rapid rate of knots.
  2. #19457
    i've had that happen - by accident...plating flaking off a surface gap plug turned it into an ignition source.
    Other than stalling it - if you realise in time - it's wait for the fuel to run out.
    personally, I'd doubt if the Ryger uses HCCI.
    I agree it's not HCCI as we know it but there is something happening to start multiple burn points spontaneously ( controlled ). At 30,000 rpm there is not much time to get combustion all done.
  3. #19458
    homologation
    "I have access to the CIK site area that holds the applications but until the formal procedure has been completed, no one can actually
    see the papers until they have been stamped as approved"
    imagine being able to have access to those papers....mean while, if they were mine id be having sleepless nights and id be dropping out little false hints all over the place to keep people off the track.
    i wonder if Frits could comment on whether this engine,outside the kart world, has room for improvement to keep all the engine tuners busy. could it be so simple?
    although, since this Ryger engine has appeared, i hanvt watched much tv and its opened my eyes to so many different types of ideas that have been patented in the two stroke world that have not materialised , why ?
    and another one http://www.ardellco.com/animations.htm
  4. #19459
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    With these karting rules, is there a requirement for a kill switch?
    GM 471/671 two strokes often had sprung plates mounted over the blower intake.
    I had to use one once, on a dyno, at more revs than I wanted to be anywhere near.
  5. #19460
    26th August 2015 - 15:32
    1980 Yamaha RD/H2 750
    Ballina N.S.W.
    I've had a Mikuni rubber inlet stub split causing an airleak on a 750 Kawasaki, do it.. & drag the 2 other cylinders along for the ride..
    When the kill switch has no effect, then stalling it - is the only quick option, but if you pull in the clutch.. it runs away..making gear selection a tad harsh..
  6. #19461
    16th September 2015 - 06:10
    Harley SShovelhead
    USA
    I guess when one only has a couple of posts to their name on here, nobody pays any attention to the content of the posts ??
  7. #19462
    hi there, i think that the patent you have directed us too was sadly dismissed as the ryger engine some time back. i may be wrong but ....
  8. #19463
    Don't bother deciphering that patent; it's not the Ryger-patent. The Ryger engine is much simpler.
    i think this was the post , motleycrue. page 1182
  9. #19464
    Its not that you only have one or two posts, its just that link was already posted some time ago. Old hat I guess. And for god sakes just dont try to start any conversation of fourpokes, especially anything to do with harley
  10. #19465
    19th June 2011 - 00:29
    Frits, do you see a future road-use for the Ryger possible, regarding emissions ?
    can it meet with Euro5/whatever is comming ? The problem I see is that it still uses an expansion chamber (and a 2T without one is a whole lot less interesting to me), so a catalyst converter before the pipe makes the pipe useless, and one behind the pipe wouldn't work (I guess) as because it wouldn't be hot enough ?
  11. #19466
    I do not concern myself with Euro5 and related legislation but I see a clear future for the Ryger in competition, road use, outboards, jetskis, skidoos, ultralights, generators, pumps, chain saws, lawn mowers, you name it. It doesn't burn oil, it uses less petrol per hp per hour, and it has a cleaner exhaust.
  12. #19467
    But the very best end use for the Ryger technology would be a retrofit kit to go on Harleys.
    Then instead of just killing endless scores of sadly deluded middle aged dudes that think they are Peter Fonda, with shit ( no ) handling and
    shit ( no ) brakes combined with no power at all,the old boys can smile as they slide down the road on their arses knowing the last thing they will ever hear was a two stroke.
    Just as an aside the stats in NZ are that 52% of motorcycle road fatalities involve the letters HD.
  13. #19468
    This has just been posted by the CIK.
    Ryger is just a rubber stamp away from changing everything we think we know about race engines,as well as
    making HDs sound like music.
    Attached Thumbnails Attached Thumbnails Homol-materiel-2016_Web provisional.pdf
  14. #19469
    Ballina N.S.W.
    Hail to the rightful King!
    I'll put my quid up.
  15. #19470
    I suppose there won't be many Hodakas still around....
There are currently 146 users browsing this thread. (0 members and 146 guests)
