Page 1300 of 2776 FirstFirst ... 3008001200125012901298129913001301130213101350140018002300 ... LastLast
Results 19,486 to 19,500 of 41630
  1. #19486
    Page 1300 .....
    Continuing with the theme of celebrating the people who aren't talking up a storm but actually working away in their sheds doing 2T tuning stuff.
    I would love to see more posts with photos of 2T tuning work that people are actually doing for themselves.
Name:	Speedpro RGV-TF hybrid.JPG
    Been chatting to TZ about a TS/RGV hybrid and finally found a few shots of an older effort. Shame I didn't know a bit more about tuning back then.
    I got a 29hp engine on triple-r-superbike dyno, the clutch was slipping bad and it was sucking in gearbox oil so i am sure there is a bit more power. On its first outing it shagged the original clutch kit and then started drinking the gearbox oil but it was still reaching just over 170kph at Ruapuna, there was more power available but I ran out of smaller back sprockets.
    I had some good help from F5Dave and Peter Steadman.
    More pictures of Bren's bike in its undressed state on the original post.
    the bike.... and engine finished
    And then the finished bike as raced.
    The 50 is together and going.
ID:	315953 Click image for larger version.
Name:	Cotswolds NSR50.JPG
    Some pix of the 2 pipes. The RS pipe is a 1991 with a hand made header. The last pic has the TZ500 pipe fitted. Never mind the fat bastard in the background, it is the only pic I have that shows that pipe.
Name:	Jason and RMS Eng KE-RG100.jpg
    Jason's RMS engineering's KE/RG100 engine in a TZ50 chassis.
    This is my machine when it was a bit cleaner.
    The cases are apart now after an ordeal trying to get those stuuuuupid case bolts out with the phillips heads, what shit idea that is. I ended up drilling a bunch out which where corroded in down the thread. Here are some photos, next I'll jump into the dummy casings with the grinder
    The size of a 125 amuses me greatly, coming for a car background. I really enjoy the ease of handling everything, no engine crane or massive engine stands and heavy manifolds etc.
    Lots of photos on Chris C's thread.
    (Insert long sigh here) I hate, I hate to ask this, because I know I've seen the answer somewhere, ... but could one of you skilled info-locators please once-and-for-all-time give a detailed step-by-step set of search directions here, to show us how to find something WITHIN the ESE superthread.
    Seattle Smitty's original post, is the start of a short thread with many tips on how to search and find good stuff on the ESE thread or any thread for that matter.
  2. #19487
    We dont see Zeroshift in everything coz the other Irish guy Mr Patented is involved.
    His 2014 updated phone number is 20100257969 I believe.
  3. #19488
    Frits,
    Congratulations on getting the FOS into production. Nice packaging and catering for a worldwide market.
    I suppose you are now working on the Ryger version.
  4. #19489
    Frits,
    I can see the protype had to be slightly modified, or refined. Is that a switch for different emission rules in various locations?
    Wait, it's a sound vs. power switch - usa setting is load as hell, but low on power!
  5. #19490
    7th December 2013 - 00:25
    Yamaha's
    Hellas
    Time Area/Angle Area calculation
    Hello guys,
    I try to figure out how can I calculate the required TimeArea/AngleArea for specific rpm and BMEP.
    For expample lets say for 125cc with 200* and 11.5cm2 exhaust port area and for 12000rpm we have:
    TimeArea: 0.00024 sec-cm2/cm3
    AngleArea: 18.4 deg-cm2/cm3 .....if I did the maths right
    My question is,
    how programs like engmod can calculate the required area for say 14bar BMEP at 12000rpm?
    Is there a formula or just Vannik's experience?Is there a method to calculate it in hand?
    Cheers
  6. #19491
    Lef i think theres some stuff in blairs book about what you want to know, although i cant speak for its accuracy or credibility because im not a engine expert. im not real sure but i thought engmod might be based on some of what blair wrote but i could be wrong. these other guys might know for sure. while im thinking of it, what do you guys make of these statments that blair wrote in his book 'the basic design of two stroke engines' pg265:
    The decision on the connecting rod length is fairly straightforward:
    it should be as short as possible to assist with the creation of a high crankcase
    compression ratio. In practice, the mechanical limitations of flywheel diameter and
    crankpin diameter necessary to withstand the mechanical loadings, and the necessity
    to have the piston clear the flywheel at bdc, will dictate a connecting rod center
    distance between 1.85 and 2.05 times longer than the stroke length.
  7. #19492
    Yamaha's
    Hellas
    pee,I don't know if you've noticed but my TA calculations were based on Jennings and not Blair's formulas.
    Because English is not my mother language I find it difficult to read Blair books so I gave it up.
    If someone have the time and can make Blair's STA formulas a little bit more simpleminded it would be good
    Cheers
  8. #19493
    I have said this before and got shot down severely by a couple of people, but even now I still just dont get it.
    Why waste time doing the calculations, what do you learn apart from the satisfaction of getting the simple maths correct.
    There are free ( simple ) programs on line that give you the actual answers to what you need to know to build an engine
    with the correct angle areas or STA numbers, that we know work in every end use.
    And there are better programs that tell you a huge amount more.
    In my view you would learn a way more by spending your time working with the correct answers on a real engine by juggling all the variables
    within the correct parameters you have been given.
    instead of working out, how to work out the answers - as its all been done before.
    Yes I know its educational and all the other admirable intellectual endgames, but in the pursuit of two stroke knowledge having the correct
    answers in front of you, is to me way more useful, than the laborious time consuming exercise of calculating them.
  9. #19494
    Why even bother with time area's angle area's or any of that?
    Ryger made everyone that has touched a 2 stroke into antiquated technology. Ryger won.
    We'll have to figure out how to improve upon his designs slightly from now on.
  10. #19495
    Why even bother ... Ryger made everyone that has touched a 2 stroke into antiquated technology. Ryger won.
    Personally I really hope the Ryger concept heralds a new dawn for useful 2T technology.
    Unless you're at the top of Kart competition, next year maybe but anywhere else, when exactly are you expecting to be beaten by a Ryger.
    Buckets is a different story ..... ... plans are afoot.
  11. #19496
    9th June 2012 - 18:32
    Bucket Sidecar
    palmerston north
    Personally I really hope the Ryger concept heralds a new dawn for useful 2T technology. But it may be a bit premature to write the old ideas off because I am willing to bet that unless you're at the top of Kart competition, and you go riding next week or month or maybe even a year or two or ever if you're into VMX or the post classic classes you are not going to be beaten by a Ryger.
    Exactly TZ, and the two stroke expansions will happen in Buckets as per usual. Not sure many of us will have deep enough pockets to buy a Ryger for a while to come (any Chinese derivatives on the market yet).
    It's a Kart motor too, might have to give the Ryger proponents a call and get one put in a commuter bike!
    Interesting development though, and very interested to see if it is a rocket or a hand grenade. Time on the track will give us those answers.
  12. #19497
    how can port surface area be irrelevant for ryger . mixture still passes in and out of the cylinder via transfer and exh passages, does it not ? something has to open and close a window, does it not ? to say the windows size is irrelevant would meen a pin sized hole would give the same results as a much larger hole.
    far as i know frits is the only one to see the engine. how can everyone else be sure whats irrelevant or not ?? johhnyquest if you know how it works i think all of us are listening with great anticipation
  13. #19498
    The duct CSA isnt near as important as the entry geometry.
    what is CSA stand for ?
  14. #19499
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    From an engineer it means Cross Sectional Area.
  15. #19500
    17th September 2013 - 01:07
    SWE
    Seeing Neels is online.
    Can we expect future versions of EngMod including the Ryger concept do you think?
    Impossible to answer, I know, but any way...
There are currently 149 users browsing this thread. (0 members and 149 guests)
