Page 1305 of 2774 FirstFirst ... 3058051205125512951303130413051306130713151355140518052305 ... LastLast
Results 19,561 to 19,575 of 41608
  1. #19561
    Don't bother, just get the die grinder (or hammer and cold chisel, if you are from Australia) and open up the gearbox to the crank case, plenty of volume and oil and lubieness.
  2. #19562
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Go back again Neil and have another look, I've got the right one on there now! - I hadn't properly checked out the one I posted originally before posting it.
    Better?
    Now I bet you wish you had gone four stroke!
  3. #19563
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    Inside, there is a "whipper" attached to the crank which whips the oil into a misty frenzy.
    Plenty of older machinery had "dippers" on the bigend, either cast in or just a bent bit of pipe braized onto the bigend cap.
    Not sure if the resulting pressure would be enough to feed the mains at 30K though...
  4. #19564
    1944 RE 1
    Yeah, the faithful old Briggs uses a simple 'slinger' (centrifugal fan?) driven off the crankshaft but as you say........at 30.000, maybe not!.
    BTW Neil, just look at this graph! - note the flat torque curve of the CX25 Honda! - you don't often see that "stump pulling" grunt from a two stroke!
  5. #19565
    Stump pulling more likely a twig tugger or a leaf blower.
    Hit and mist lubrication went out with 1920's indian scouts.
    Plain bearings need pressure
  6. #19566
    seems like someone mentioned something about the piston being cushioned possibly. would that be possible if the crankcase was mostly sealed with all but a small vent ?
  7. #19567
    1944 RE 1
    Oh? - well, guess even I can be wrong sometimes!
  8. #19568
    Well I could be too, but the old mist lubrication on the Bert Monroe Indian hamstrung the bike somewhat, even when argumented with the std Aux plunger the bearing turned a nice pretty shade of blue after each run.
  9. #19569
    If you want huge pumping losses, there is no better way Peewee.
  10. #19570
    1944 RE 1
    He only needed one good run!
    Sorry, we're becoming a little flippant Frits & Peewee, but we're keeping the thread going (for the first time) because the Rugby World Cup and Moto GP are hogging all the attention at the moment!
  11. #19571
Name:	28hp 4K dyno curve.jpg
    This is my Suzuki GP125 in its 28hp and pumper carb days, those long flat 2T torque curves are a common feature for the GP.
    The GP uses mist lubrication of the piston and crank bearings too....
  12. #19572
    Records are set with two runs within an hour in opposite directions.
  13. #19573
    19th June 2011 - 00:29
    I think it was even mentioned earlier on, a small measure of oil in the crankcase which is splashed about the place by the bigend whizzing around. Splash feeding everything would not take much oil, maybe 100cc or so. No oil pump required.
    100cc in a 125cc 2-stroke crankcase, that would probaly fill the crankcase up to the shaft and than you would have the big-end go through it every rev ? it would lubricate it yes, but it would cause a lot of resistance/friction, not only going through but also between the crankwebs and cases.
    and how many engines do you know that use only 100cc to lubricate it, and can withstand up to 30.000 rpm without overheating the oil ? Even if you do oil-changes quickly , how are you gonna do them ? take of the cylinder each time ? install a drain plug (that in some engines needs to go through the water jacket arround the cases) ?
    would give the same problems as above as the level of oil would need to remain the same if you want to keep your gearbox alive, and you'd allow unfilterd gearbox in your bearrings and big-end - in some engines even oil diluted with clutchwear.
  14. #19574
    1944 RE 1
    True, and if we are looking for friction free bearings I guess needles are the best way to go, even the Guzzi V8 with its one piece crankshaft (rods with split big ends and cages). - no high pressure oil needed there.
    I guess that two strokes can be made to have whatever torque curve you like by appropriate port timing, just like four strokes can be manipulated by changing the cam timing.
    BTW. I remember Suzuki two strokes having oil pumps delivering oil directly through the crankpins, but the racing guys preferred to discard the oil pump and use conventional petrol/oil mix, why was that? was the amount of oil they delivered a bit unreliable?
  15. #19575
    Well you’re right Fletto. The point being we can always get better with time. Just look at us Ozzies, hammer and cold chisel one day then just one guy blacksmithing a Ryger con rod
Name:	One rod at a time.jpg
    a few years later we then had a team of guys making them, soaring production levels.
Name:	Soaring production.jpg
    Even our close neighbours across the Tasman, they have developed, refined their methods as well. Particularly with farming, where good locations are essential. Location, location, location, the catch cry of real estate agents the world over.
Name:	Location location.jpg
