Thanks, Frits; I'll try it. I'll see if I can delete it here (Adegnes, I don't understand what you're trying to tell me).
The "canoe" in the video appears to be a Taiwan Long Boat.... I have talked to individuals that race these things in Taiwan. Was told its a sport that is kind of off the charts, strictly amateur, but finding huge popularity in some regions. Below is a link with a little more info.
http://www.john-tom.com/Klong16/LongTail.html
Kermit Buller
Hi guys,
after reading this thread almost daily for more than half a year and seeing so many interesting projects, I really thought I should start sharing my project with you instead of just reading and not contributing.
However, I really don't know where to start so I'll just drop into the middle of it. Together with a friend (who is the driver), we compete in the dutch 150m dragracing / sprint championship 70cc shifter class.
The bike was originally a 2007 derbi GPR which we modified to make it lighter and more powerful. Currently, the weight is at about 47 kg with approximately 27 - 27.5 hp and we are doing the 150m from a stand still in 6.71 seconds.
For next year however, we would like to go faster, therefore (and to learn more about 2 strokes), we are in the process of making our own cylinder.
I have made multiple silicone prints of the transfers and exhaust of a honda 125 a-kit and an RSA and tried to mix it all up with the comments from Frits and Wobbly.
The cylinder has been drawn in a CAD program and 3D printed in PLA after which it was cast in aluminum by using investment casting. At this moment I am machining the raw cast piece and making an adapter plate / head inserts, etc.
For now I think this is enough before my post becomes confusing. In the attachments I have posted a picture of the bike, the cylinder, its mold and the cylinder during the investment casting process and the power curve
cheers,
Peter
^^ very cool! ^^
I saw that tape, and wondered the same. ... but really curious as to why you installed drum brakes? Less weight?
Thanks guys!
Actually Adegnes, years ago the competition started out as street mopeds / buckets.
However, the compitition has progressed and because I'm a mechanical engineer, I love to make strength and weight calculations to gain every possible ounce :d.
The tape in the front wheel is to ensure the optical sensors don't shine through the wheel at the start.
The time registration system was build for original tires which were much higher, therefore the system doesn't cope well with our wheel.
Here is a movie of a test drive
https://www.facebook.com/sprintperfo...type=2&theater
Peter
On the Ryger maybe its not high crankcase compression at all, maybe there is no crankcase compression. Firing off a 2 stroke with no crankcase compression is not a problem with just a simple addition, and running in the powerband with no crankcase compression is possible (24/7).
But idling with no crankcase compression and a normal 2 stroke exhaust I'm not sure that would work, I'm guessing it wouldn't, but I never tried it. I bet there is a way to do it though. More thought required.
There are currently 168 users browsing this thread. (0 members and 168 guests)
