Page 1320 of 2774 FirstFirst ... 3208201220127013101318131913201321132213301370142018202320 ... LastLast
Results 19,786 to 19,800 of 41608
  1. #19786
    12th August 2015 - 03:31
    GSXR600
    Canada
    Maybe so; there are lots of things I'd like to measure but it would require more instrumentation than we have available at the moment.
    If you ever wish to pursue that additional instrumentation (pressure analyzers, high speed combustion pressure sensors, high speed port pressure sensors), we (TFX Engine Technology Inc,) would be happy to discuss supplying one of our systems to you. Maybe there is another 5 or 10 HP waiting to be picked, or maybe more importantly it would simply be good data documentation to provide to investors, marketers etc. comparing the internal instantaneous dynamics of the Ryger engine, to conventional 2 strokes, and to 4 strokes.
  2. #19787
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    The Ryger has an conventional looking pipe, so the pressure ratio at the Ex around BDC , and thus within the cylinder
    will be the same.
    But - if some of those 11 transfers are located high and connected to the small volume under the piston, and the higher pressure at EPO is used to compress that volume,
    then we have the situation that the pressure ratio at "normal " TPO will be far greater in the case than within the cylinder.
    The exact opposite to what is seen in a normal 2T.
    When the transfers first open we get backflow, as the case pressure is so low and even with a ton of blowdown STA the cylinder pressure
    is still above whats in that case.
    So I envisage some high transfer ports connected thru lower down holes in the piston to the small case area, separated as we know by the CNC plate
    and some sort of seal on a vertically sliding piston guide rod.
    The trickery in the sump is still beyond me, that enables safe operation at 30K - but as I inherently believe what Frits has alluded to,its as simple as buggery
    and why non of us thought of it before is madening.
    More power to Mr H Ryger.
    I am anxious to see how can it be done. He is making us feel like we are dumb
    70cv in a 125cc with less 80% emissions, if this will be realiable it will put 4 strokes in the trash can
  3. #19788
    Your philosophies about the Ryger engine make it very tempting for me to react. Alas, I still am not allowed to. But I can't resist re-posting this picture:
    I bet you wish that you could push that piston further down. But what would you see? Let me tell you: nothing out of the ordinary.
    Even with the piston at BDC you would not notice that it is a Ryger engine...
    Ok Frits, I will if you will, here I've pushed the piston down to uncover the ports.
    The irony of it, hot sleeve edge might be a good thing after all
ID:	316312   Click image for larger version.
  4. #19789
    Leiria, Portugal
    I am sorry if this is total nonsense, but any rod rotating at 30k rpm would break in pieces, so my ideia is that is just goes up and down.
    What about if the rod just puls a ratchet system down, and is forced up by a spring with exact strenght needed to compression stroke at maximum hp?
    Like in the pic, but I can't picture that working at 30k, there would be so many problems
  5. #19790
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Quote Originally Posted by polinizei View Post
    Maybe you guys remember that post with a rised C port, some posts ago, where Frits asked for the source...
    I may have been the guy who posted about the use of high back boost port, (maybe slightly higher than the exhaust port).
    I read about it somewhere, possibly in the British "Motorcycle" magazine and possibly way back in the seventies. - I didn't see a post where Frits asked for the source of the info.
    I can't really tell you any more than that and probably don't need to tell you, that those early fast two stroke racers, although they had high horsepower readings, also had exceptionally narrow power bands!
  6. #19791
    1944 RE 1
    Frits, it's now your turn to do likewise!
  7. #19792
    Page 1320 ....
    Maybe not the Ryger but a very informative read.
    And how to hydroform an expansion chamber.
    After reading some of the content in the ESE thread, I've become really inspired to take a closer look at hydroforming chambers.
  8. #19793
    Attachment 316216
    Jeez, we could make these OR could we? It all comes down to the patent status and tactics, which is all a bit of an unknown to virtually all of us. The main feature of patents is that no-one can “make – use – sell” a patented technology unless they are the patent holder or one who has been given permission to use it, eg a licencee. Lodgernz might be able to comment further
    So if Smitty,TZ350 and co made one, even for their own use, it could be deemed to be in breach and Harry could take you to court and try to claim damages.
    Talking about patents in general, the way I understand it, once a concept is known a patent protects the patent holders commercial interests but patent law does not stop you using the new knowledge to make your own version of it for your own personal use.
    Certainly a patent prevents you from exploiting the new idea for commercial purposes but it cannot prevent you using any new knowledge you have acquired to make improvements to your own lot.
    Think home hobbyist making a model steam engine incorporating the latest slide valve technology or the offroader modifying his own vehicle to turbocharging and the latest duel fuel rail technology so as to be more powerful and fuel efficient.
    From good old Wiki:- The definition of patent infringement may vary by jurisdiction, but it typically includes using or selling the patented invention. In many countries, a use is required to be commercial (or to have a commercial purpose) to constitute patent infringement.
  9. #19794
    1944 RE 1
    The way I understand it, once a concept is known a patent does not stop you using that knowledge to make your own version of it for your own use.
    Certainly a patent prevents you from exploiting this new knowledge for commercial purposes but it cannot prevent you using that new knowledge to make personal improvements to your own lot.
    Yes but if someone was actually using your expensive patent "illegally" and you hadn't sold a lot of them, then would you and your little company have the wherewithal for good lawyers or the time to pursue the patent rights to the ends of the earth (or even to China! or India).
    Wagging a finger at them or displaying the 'V' sign from the door of your little workshop won't save you!
  10. #19795
    in the photos we've seen it doesnt appear a ratchet system would fit in the normal looking crankcases
  11. #19796
    To be honest Frits I think we sort of know what's happening down below now, how about turning the camera on the cylinder head (combustion chamber). Please and thankyou.
  12. #19797
    .. a conversion is just a new piston,conrod, spacer/valve plate and some cylinder lower end rework.
    Yep. Well, just about. There are some minor appliances handling crankcase breathing etc, but as far as the fundamentals, you nailed it Neil.
  13. #19798
    ... can we take this as confirmation that there is a reed valve somewhere in the inlet tract ?
    Clear as mud, aint it? I even gave away where this 'somewhere' is.
  14. #19799
    Quote Originally Posted by nitro2tfx View Post
    I do not usually respond to commercials, but a dutch acquaintance of mine is using TFX and I must say the stuff is good, the support is good and the coaching is good.
    I may take you up on your offer in due time .
  15. #19800
    18th July 2015 - 16:21
    2015 Avanti
    Yep. Well, just about. There are some minor appliances hanlding crankcase breathing etc, but as far as the fundamentals, you nailed it Neil.
    Thank you Frits.
    Neil
