And none of that is fantastic ???
Let's not confuse "fantastic claims" or "miraculous claims" with being untruthful. Nobody is saying it is untruthful.
Big money will take what big money wants, and by "big money" I dont mean Harry lining his pockets with money, I mean those entities that want what Harry has got and intend to get it one way or another, if the Ryger engine is seen to have the far reaching potential we all hope it does.
its in a museum in Aussie there is a write up on the aussie bucket page, team mad dog or something similar.
http://www.powerhousemuseum.com/coll...se/?irn=350521
http://www.teammaddogracing.com/
gee they bred like rabbits over there
https://nmrm.com.au/racing-in-bathur...etq-racer.html
Willy,
The force diagrams were based on a conventional 2 stroke construction. However, if one say used a method such as suggested by a certain Brett S in post #19937, then things would be different. The more I look at the forces and their exponential increases with speed, and this with the short rod and generally well known limited bearing life at 17k levels, then there must be something else going on. Is it just the fact of lots of lube available, some cushioning, double acting combustion or whatever allows it to survive? Dunno.
Frits knows. Frits, how about another info clue or leak? It's been a while.![]()
Hi,
just like many others I got hooked to this excellent thread, wife thinks I'm having an affair with some old love. My first bike was RD350 so she is partly right.
Unfortunately I have no information just some more questions to show my total lack of knowledge in these piston force calculations.
Does the late ignition made possible by HCCI effect the piston forces? I was thinking that it is the acceleration that is killing the engine in 30 000rpm, if that could be reduced somehow then it could survive. The other possibility is to have stronger/lighter "piston/conrod".
It would be also interesting to calculate backwards that if we had 30 000rpm, what would the other parameters be if the engine was to survive according to our current knowledge.
Yes it's a very promising project but there's no fantasy involved, probably all hard graft and a large dose of reality! ........and yes, I understand what you are saying of course and undoubtedly you are correct about "big money" but that's how it always has been.
I live in a small country where a lot of brainpower has been lured and dragged elswhere by "big money" - those big money countries then claim them as their own if they are successful and we are still just little old New Zealand with nothing but sheep and cows (and an obscure flightless bird) for the rest of the world to identify us by!
Holland is a little country too, but being part of Europe, they have access to a huge market for their engineering expertise which they are quite capable of exploiting and doing it directly from home and - they are very capable engineers and businessmen.
Basically I think we are in agreement - more or less.![]()
Yea was confused by that pic. The barrel is MB100 but I thought you only got H100s over there. Perhaps there are H100s that use MB parts in some countries but would need new frames.
Mike has had 30hp from his, mine approaches that. Still more to come but OK for 1978 tech.
Yes some countries called what we had as the MB100 was called the H100.
There were three variants in the Hayes manual.
from memory the H100s we got after the Mb100 was left over run for an Asian country BlueWing got hold of and put on the market here hence the lower spec with 4 speed and points ignition.
The Gl145 was the similar sort of deal. (a market run intended for somewhere else)
The MB100 has the 5 speed the electronic ignition racier port timing and different fining its a better starting point due to its bigger fining. IMO
Those Aussie buckets had to run std frames
Ken Asked me to post this spreadsheet after converting the possums to pounds for paddocks or something
Won't work I will fix it later
does anyone know of any piston manufactures that do single ring pistons with the ring locator pin centrally located at the rear of the bore
to suit 250 mx engines
have tried vertex but even their single ring race pistons have offset pin locator to line up with a transfer bridge
cheers
the Site that I will link list the ring locations
http://www.pvlsverige.se/vrm/index/index22.html
I will add to the list later most are rods
but have a look at TKRJ and Prox plus makita can't find the site at the moment or they changed it site for sizes try some of the 250 karts like Rotax
can't remember who used to make the pistons for them? some Austrian company
ELKO
http://www.ebay.com/itm/KTM-250-300-...ef24f0&vxp=mtr
have a look at KTM.
Woosner, Wiesco
http://www.mitaka.co.uk/CATALOGUE/PISTON_DIMS_ALL.htm
URL="http://www.mxcomposites.com/con_rod.php"]http://www.mxcomposites.com/con_rod.php[/URL]
http://www.connectingrod.com.tw/ktm.htm
http://www.pro-x.com/downloads/Technical.pdf
http://www.kevinbreedonracing.co.uk/...ts_conrods.asp
http://www.connectingrod.com.tw/honda.htm
http://www.samarin.nl/webshop/index....ewCat&catId=32
http://www.tkrj.co.jp/
http://findebookee.com/c/connecting-rod the one is capt
http://dl.dropbox.com/u/399336/Pictu...ted/HotRod.pdf
http://www.kingrod.com.tw/products.p...t&pc_parent=22
http://www.crankshaftparts.com/index...7_93&limit=100
http://shop.atlanticmotoplex.ca/prod...catalogId=2016
http://jjmachineryonline.com/snowmob...onnecting-rods
http://www.scooter-center.com/scoweb...y2=CAT&lang=en
http://www.bansheedepot.com/products.asp?cat=17
http://http://www.samarin.net/?productos
http://www.pvlsverige.se/vrm/index/index22.html[/QUOTE]
http://www.con-rod.com.tw/motorcycle-connecting-rod.htm
http://www.google.co.nz/url?sa=t&rct...MVppLeMVAqjHUA
Correct the Poms got the 4 speed I the MB50 restricted most other markets only got the 5. We and I think Aussie and the USA (one year only imported)got the 6 speed.
The four speed is an all up Ag100 style.
The 5 is the exact same ratios as the CB50 and XL100S.
All the Mb100's were 5 and the H100's we got were the 4.
there was also a MB8 which is a MB100 engine debored to 80 with a 5 speed only a few euro countries got those though I think.
The Cr80 aircooled is a lot closer ratios and bolts in although 5-6 is a bigger jump.
pretty sure the Takakawa and similar boxes use late model CR85 gears although there is other custom ultra close gear ones as well. All illegal for Buckets mind you and ubber expensive.
Ahh now that's where you are wrong, the US got 5 speed 50s or at least some were, our MBs were 4, or at least the ones I've taken apart were.
The H100S was 4 but all down. The MT50 was 5.
Anyway I'm done being a trainspotter, none of this seems so funny anymore.
There are currently 264 users browsing this thread. (0 members and 264 guests)
