Page 1339 of 2776 FirstFirst ... 3398391239128913291337133813391340134113491389143918392339 ... LastLast
Results 20,071 to 20,085 of 41629
  1. #20071
    ..my plan was to weld the dam on all sides, preventing any oil or fuel from entering the airgap..
    If you weld the dam on all sides so the air gap below it is completely sealed off, then why not take the opportunity and turn that air gap into a coolant volume?
    It would be great to have a raised exhaust duct floor from say 3mm sheet material with water flowing underneath.
  2. #20072
    11th August 2015 - 01:42
    Henderson Ne USA
    Piston interchange question
    Without luck I have been trying to find the proper forum to ask the following question...
    Older YZ250 pistons are commonly used in the Current YZ250s as big bore pistons. Depending on the model the wrist pin height is 2mm to 5mm lower..(which is not a problem for my this aplication) Are there certain models to avoid because of ring pin location, ex bridge holes, miss matched ex skirts, etc etc?????.
    Can somebody suggest the proper forum to ask this question?
    Thanks Kermit Buller
  3. #20073
    thnx for the tips frits. i didnt think about having water go through the underside of the dam but it would be easy enough to do. water flows around the exh port now so all i would have to do is make two holes through the floor so the water can pass in and out from underneath.
  4. #20074
    Quote Originally Posted by 2005bully View Post
    if your wanting a standard sized 250 piston with pegs directly in the rear then check out the ktm250. im not sure if any of the other 250 engines used 6' 0clock pegs . you can look at pictures on ebay and get a idea what each piston looks like. you can always have the pegs relocated also
  5. #20075
    PS the Piston maker I couldn't remember the name of that made pistons for Rotax was Elko
    http://www.ebay.com/itm/KTM-250-300-...ef24f0&vxp=mtr
    Some older Huskys and KTM's might suit
    http://www.ebay.com/itm/Mahle-Standa...085724&vxp=mtr
    This lists a fair bit of information on each years changes
    http://www.mitaka.co.uk/CATALOGUE/PISTON_DIMS_ALL.htm
    YZ250
    http://www.mitaka.co.uk/YAMAHA%20PISTONS/PT.88YZ250.htm
    http://www.mitaka.co.uk/YAMAHA%20PISTONS/PT.99YZ250.htm
    RM250
    http://www.mitaka.co.uk/SUZUKI%20PISTONS/PT.87RM250.htm
    http://www.mitaka.co.uk/SUZUKI%20PISTONS/PT.96RM250.htm
    http://www.mitaka.co.uk/SUZUKI%20PISTONS/PT.98RM250.htm
    http://www.mitaka.co.uk/SUZUKI%20PISTONS/PT.99RM250.htm
    http://www.mitaka.co.uk/SUZUKI%20PISTONS/PT.00RM250.htm
    http://www.mitaka.co.uk/SUZUKI%20PISTONS/PT.03RM250.htm
    KX250
    http://www.mitaka.co.uk/KAWASAKI%20P...PT.87KX250.htm
    http://www.mitaka.co.uk/KAWASAKI%20P...PT.90KX250.htm
    http://www.mitaka.co.uk/KAWASAKI%20P...PT.92KX250.htm
    http://www.mitaka.co.uk/KAWASAKI%20P...PT.05KX250.htm
    KTM250 and 300
    http://www.mitaka.co.uk/OTHER%20PISTONS/PT.05KTM250.htm
    http://www.mitaka.co.uk/OTHER%20PISTONS/91.6394.htm
    Husky 250
    http://www.mitaka.co.uk/HONDA%20PISTONS/PT.97CR250.htm
    Honda Cr250
    http://www.mitaka.co.uk/HONDA%20PISTONS/PT.05CR250.htm
    http://www.mitaka.co.uk/HONDA%20PISTONS/PT.02CR250.htm
    http://www.mitaka.co.uk/HONDA%20PISTONS/PT.86CR250.htm
  6. #20076
    Yeah we've only 100cc, 125s have carb restrictions.
    Never found that bearing to be a problem. Maybe you had case alignment issues?
    Everyone had a issue with that bearing, think it was the bearing itself as the rivets/cage would disintergrate with hindsight(and nearly 20yrs of learning) a polymide cage would probably fix that. The finning on the cylinder could never get rid of the heat though, but beat the four strokes until they were allowed 200cc
  7. #20077
    16th September 2015 - 06:10
    Harley SShovelhead
    USA
    This is something I am looking at having done on a different engine and have no experience with it. Are there any tricks to it, how much of a press fit is needed etc. etc. ?
  8. #20078
    it may depend on the type of piston used and material of the peg. wiseco told me their pegs are around .003" interference fit if i recall. i think they just use a standard carbon steel.
  9. #20079
    The old Double the size trick huh? That'll make it nice and unfair.
    Was thinking about the MX application of the Ryger, there could be a market to be tapped right there. Get in bed with TM and KTM and watch watch what happens next. Clearly protests, but they are still legal and if emissions reduce then it is harder to argue against them. Maybe. But you wouldn't want to wait too long.
  10. #20080
    29th January 2015 - 09:21
    kart
    wellington
    to follow on from peewee,s post and ask a few questions that may help both of us with our exhaust post modifications . maybe Frits and Wobbly could comment and head us in the right direction .
    My idea was to weld a vertical plate just inside the ex port entry up to a height just below tpo then weld from the base of the plate gradually raising the height of the ex port duct floor to achieve the exhaust duct exit shape as recommended by Wobbly . The reason for the vertical plate was to eliminate a heap of welding they may cause some barrel distortion , also its difficult to get into such a confirmed space to weld
    I don't think that the bottom half of the port does much apart from allowing a big radius that gently pushes the ring back in , but the vertical plate may effect the returning mixture by forcing it upwards towards the cyl head as it enters the cyl and may effect the way the pipe works on the transfers , it could possibly be a help , that's something I don't know
    If you think that the vertical plate is not a bad idea , would there be a better way to do the transfer ports . as the ports are commonly angled upwards and away from the exhaust to minimise the mixing of the incoming fuel with exhaust and reducing the incoming fuel to enter the exhaust port and as the vertical plate may eliminate this problem there may be some power gains by changing transfer port angles
    cheers .
    Attached Thumbnails Attached Thumbnails Click image for larger version. Name: exhaust port 001.jpg Views: 0 Size: 396.8 KB ID: 316578
  11. #20081
    First time I've seen this 6' Oclock indication for the ring peg position. But it's perfectly logical; I love it and I 'd like to adopt it.
    Now I'm just wondering about the correct spelling: 6 Oclock , 6-Oclock , 6 O'clock , any more variations?
  12. #20082
    12th March 2011 - 02:31
    r6ypvs hybrid
    0600 1800 Six Oclock....
  13. #20083
    Hmmm... It hasn't the appeal I was hoping for. What would the correct notation be with a combination of the digit 6 and the text 'clock' ?
  14. #20084
    Beer position?
  15. #20085
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Six of the clock = 6 o'clock
There are currently 178 users browsing this thread. (1 members and 177 guests)
  1. Vannik
