Page 1347 of 2773 FirstFirst ... 3478471247129713371345134613471348134913571397144718472347 ... LastLast
Results 20,191 to 20,205 of 41584
  1. #20191
    5th January 2013 - 13:23
    89 KX500
    USA
    Ken's photo reminds me of the early McCulloch kart engines that had a boost port duct that bypassed the reed plate. People were quick to remove the divider wall so all ports were fed by reeds, only. This was in the age of box mufflers and crappy pipe designs. Maybe a late opening C port and an effective pipe could be made to work.
  2. #20192
    Philou,
    The pins we use are around 8 long and dia 1.55. They have a taper on one end and also have a longitudinal slot to prevent any hydraulicing ?(from say coolant) when bring pressed in. We drill the piston with a 1.5 drill, giving a 0.05 interference. The actual force to press the pin in, at a guess, is around 800 - 1000 N.
    Attachment 316705
    if the pin was installed from the top down with weld over the top i wonder if a press fit would even be necesarry ?
  3. #20193
    28th October 2011 - 20:02
    RGV
    Pommyland
    My belief is that the Ryger is using "direct transfer technology", ie some of the 11 transfers allow direct passage of flow from the inlet straight into the cylinder without having to go thru any connecting volume.
    Wob, you wanna put some meat on the bones of that sysopsis
  4. #20194
    Usually good rulebooks also include *and anything may be deemed legal and or unlegal by sanctioning body at any time.
    You call that good?? It means you can as well throw the book away because in case of a difference of opinion you will have nothing to fall back on.
    It's the same with remarks like "This is not within the spirit of the rules". Damn the spirit; something is either written down or it isn't.
    It is the responsibility of the rulemaker to make and keep the rulebook simple and unambiguous.
  5. #20195
    No I don't call it good.
    It's their way of giving up and giving themselves a loop hole.
  6. #20196
    So which forum member was closest on Ryger design?
  7. #20197
    Hold your horses Jonny. I can't answer that question until the new patent has been made public. But by then you can decide for yourself.
    (I do have a fairly short shortlist ).
  8. #20198
    Eh, you're to smart for your our own good.
    Take the bait!
  9. #20199
    4th June 2013 - 10:03
    2010, specialised bike
    United Kingdom
    Or it's not worth the paper it's not written on
  10. #20200
    13th September 2014 - 05:14
    '76 RD-400C
    The Emerald City
    I've been formulating technical regulations for various types of motor sport during the last couple of decades, but before that I practiced reading between the rulebook lines all my life. And the CIK karting technical regulations are a joy.
    Small example: in some classes it is not allowed to add ports to the cylinder. So what are ports? Let me take you on a wonderful trip through the rulebook....Suppose I add two auxiliary exhaust channels with rectangular cross sections. Since they are neither cylindrical nor cylindrical-conical, they do not qualify as ducts.
    So their intersections with the periphery of the cylinder do not qualify as ports either.
    Don't you love it?
    Outbaord racing would love to have you, Frits.
    Rules: displacement, un-blown, any liquid fuel. Home-made engines legal and greeted with enthusiasm by the members.
    (EDIT) Oops, no nitro in European racing.
  11. #20201
    11th August 2015 - 01:42
    Henderson Ne USA
    If that mystery lump on the barrel is some kind of pressure bleed port from the exhaust, and looking at what you've both posted, could we be looking at some form of pressure wave compressor ? Comprex comes to mind as an example vaguely similar in function. IMO, very little primary compression is needed at cranking speed to fire things up, just get a little vapour in there...
    But of course, I'd think a form of pressure wave compression would fall down on the no supercharging clause.
    Grumph...In all normal 2 strokes the movement of gasses is initiated by mechanical means, but as the movement of these gasses continue, it becomes assisted by non mechanical means. With that in mind wouldn't the normal 2 stroke definition of supercharging need to involve an additional mechanical method of pumping. If simply pressure or wave energy is robbed from the power stroke (or exhaust) it would seem hard to label it as supercharging. The concept uses the same basic principles as a normal 2 stroke, it just uses a different method of application.. Kermit Buller
  12. #20202
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Philou,
    Attachment 316705
    A very big thanks Ken
  13. #20203
    Quote Originally Posted by 2005bully View Post
    While the movement of a piston is a mechanical means, the gas moves due to the pressure differential thus created. I think it's well proven that the depression created when the exhaust opens has more to do with drawing the charge in than any positive displacement from the descending piston.
    To adress the labelling of a supercharging function...As I understand it, the rules prohibit any additional supercharging device. This is very probably a way around the long perceived "internal compression" of the "orthodox" 2 stroke. From what I've read, post WW2 the 2 stroke was only allowed to remain legal despite the apparent supercharge because no one thought it would ever be competitive...
    As Frits has pointed out, drafting rules is a minefield. Been there for years here in NZ, large portions of the MNZ rulebook still have my fingerprints on them...The fact that they're largely unchanged merely says to me I got lucky. A continuing hobby is submitting remits tidying up bad rules, lol.
  14. #20204
    RGV
    Pommyland
    Here's the FIA F3 Tech rules definition on supercharging from 2013. A somewhat more comprehensive volume of regs.
    1.11 Supercharging:
    Increasing the weight of the charge of the fuel/air mixture in the combustion chamber (over the weight
    induced by normal atmospheric pressure, ram effect and dynamic effects in the intake and/or exhaust
    system) by any means whatsoever. The injection of fuel under pressure is not considered to be
    supercharging.
    If that was dropped into todays CIK-FIA KZ2 regs, all current homologated engines would pass
  15. #20205
    It's the same with remarks like "This is not within the spirit of the rules". Damn the spirit; .
    Well that's Bucket racing fucked.
    What about this gem that was uttered by a then MNZ official-
    'Bucket Racing is a self policing class'....
There are currently 200 users browsing this thread. (1 members and 199 guests)
  1. Viking
