Page 135 of 2776 FirstFirst ... 35851251331341351361371451852356351135 ... LastLast
Results 2,011 to 2,025 of 41632
  1. #2011
    Buckets4me have you had a look under Dads bench lately? a bunch of GT125 engines have appeared there, and there is also a large offcut of 2mm copper sheet in the corner. What does all this mean????
    I had noticed the nice new looking one on the bench last time I was there
  2. #2012
    Ahh C'mon it was a joke.
  3. #2013
    [QUOTE=speedpro;1129660904]The rules are pretty well spot on. TZ has proved it is possible for a 125 with a 24mm carb to make competitive power.
    Has he?
  4. #2014
    [QUOTE=jasonu;1129661585]
    Has he?
    he proved that last year 18-21 hp at the rear wheel with a 24mm carb (proved that the carb is the restriction as he is getting 22+hp out of a 100 with a bigger carb)
    now he is trying for lots more power (and he has 2 options)
    just waiting for the dyno results to see how it's going (the seat of the pants say he is onto something)
    thats reliable Hp to (1 bike has been going 4 years)
    now how many other bikes are doing that ? ? ? 2 or 4 stroke
    speedpro had a 100 that was good till it spat him off big time
    ??? any other bike out there (not many fxr's that old or reliable)
    JC cb125 twins arn't as reliable (but have been around longer)
  5. #2015
    Hey Buckets4Me I was poking around at work looking for some flat bar and found hidden in a corner a couple of RG400 cylinders and an RGV cylinder that looks like it is being converted to air cooling. I think Dad is up to something he is not telling us about...
  6. #2016
    he is always up to something
    pitty there wasent more of him and a winning lotto ticket
    then we would see some cool buckets
  7. #2017
    Picture-01 The plenum
    Picture-02 Comparison of the new inlet tract with the an original
    Picture-03 33mm straight shot into the crank case
    Picture-04 New Delta rolling chassis
    I have found a problem with running premix through my plenum. With a normal setup petrol/oil premix usually enters the motor wet and as the petrol evaporates the oil is left behind to lubricate things. But with my engine the wet fuel is evaporating in the plenum and leaving a lot of oil behind there and I wonder how much oil is actually making it into the engine.
    So I have converted the motor back to a normal carb configuration, I had removed all the auto lube bits from the engine so I will now have to build a completely new one with auto lube. The up side is I have recently acquired a Delta and will fit the new engine to it. Chambers and I feel we have gone as far as we can with the GP frames and have been able to get ourselves two FZR250 Deltabox rolling chassis which we hope can be competitive handling wise with the FXR's.
    The great thing about the Delta chassis is that its big enough to take almost any engine, 2-stroke single or twin, supercharged 4-stroke or even a Loncin or FXR if we get desperate.
Name:	Plenum Chamber-01.jpg
ID:	200241   Click image for larger version.
ID:	200242   Click image for larger version.
ID:	200243   Click image for larger version.
Name:	Delta Frame.jpg
  8. #2018
    4th November 2003 - 13:00
    BSA A10
    They are considerably better handling wise than the FXR frame
  9. #2019
    Did you manage to get the bike on a dyno ?
  10. #2020
    10th December 2008 - 07:39
    07 fz6n. 07cbarrrr600
    STRAYA
    Any idea what a "castec" frame from a honda spada would be like in comparison ? I don't know anything about the delta box..
  11. #2021
    Alexi and Chambers flat out fitting a GP125 engine to one of the FZR Rolling Chassis.
ID:	200669   Click image for larger version.
ID:	200670   Click image for larger version.
Name:	01-GP Engine.jpg
ID:	200671   Click image for larger version.
Name:	02-GP Engine.jpg
ID:	200672   Click image for larger version.
Name:	03-GP Engine.jpg
  12. #2022
    Cable ties. Check
    Blocks of wood. Check
    Spocket 12" from swing arm pivot. Check
    Engine considerably higher than wheel spindles for super high COG. Check
  13. #2023
    20th November 2002 - 11:00
    Wellington, New Zealand,
    Cable ties. Check
    Yeah; you funny guy.
  14. #2024
    Cable ties. Check
    Std features with an FZR but not found on an RS chassis, you could upgrade if you want to.......
  15. #2025
    Cable ties. Check
    Miserable prick!
    Surprised you didn't mention the hefty weight as well...
