Frits, if I remember correct you have made an own design of piston pin plugs, made out of PEEK may be? I'm looking for some plugs for my engine and would have access to (standard, means not GFK reinforced) PEEK but no good idea about the design. So if you allow me to ask you if you could give me an idea (or may be sell that idea :- ) )how that plugs would need to look like. Of course I would be able to design "some" plugs but I'm afraid if they would fail (and most probably the first design(s) will) that the engine will be destroyed...
wbr from Hanau
Juergen
Regan, as a simple experiment, disconnect the balancer. See where that moves the vibration.
so the emissions tested at 5000rpm, if an engine /exhaust system is designed for full power, maybe 10,000 plus. with this engine good emissions results seem wrong. the exhaust only works proper at 10,000 rpm ish.... as the super charging effect is best at 10,000 rpm ish. . the stuffing back of fuel pulled into the exhaust header can only be pushed back best at its designed length....at lower rpm it doesn’t work , it hits the rising piston and probably goes out the stinger as unburned fuel.. no good for emissions..... so could having a port in the piston below the rings on the exhaust side allowing this fuel to return into the area below the piston at the lower rpm be of benefit,if the pressure below the piston at that point is lower than the returning pressure wave from the exhaust wouldnt it just love to pour into that space...?? wouldnt we be in the area of diverging / converging areas. and whilst increasing speed of pressure flow not increasing bulk flow.( my interpertation of a previous post with info from wobbly).
Seems to make some sense to me, except Frits said looking in the exhaust port we wouldnt see anything unusual moving the piston top to bottom. I think thats what he said, but I am not sure, those little tidbits of info are spread out all over the place and my memory is not the best.
Also with HCCI and a lean mixture (I'd bet they use a lean mixture as well as exhaust and ultra retarded timing to make the HCCI work), any fuel air mixture that does not get put back into the cylinder or crankcase through the exhaust port might actually burn in the pipe. Might. If it does then emissions would still be good and fuel economy while not perfect would still be better than for a regular two stroke due to the recycling effect.
Even if this is not in the Ryger engine, I think it still has some merit, blow the motherload as directly as possible into the exhaust port through the cylinder then stuff it all back in somewhere, some into the cylinder and some into the crankcase, % of what goes where depends on rpm. Probably with this setup the regular size stinger could support 70 HP which seems to be what the Ryger is using.
Thing is at severe overrev nothing gets stuffed back into the crankcase but instead fuel air mixture gets pulled out of the crankcase into the exhaust. If there is enough raw fuel air mixture sitting in the port when the exhaust opens next time around it could light off and make the pipe work better by sort of exploding down the pipe reaching the converging cone sooner so the pipe sort of works at insane revs. Maybe there is a point of balance reached.
My pick is that the balance shaft and crankshaft should each be 50% of the reciprocating mass (piston assembly plus upper conrod). So that at mid stroke the balance shaft and crank balance out each other and at TDC and BDC together they balance out a 100% of the reciprocating mass.
Early on Thomas demonstrated how to balance a single cylinder crankshaft. Some of the early posts below.
And a bit more to think about:
"Suck and See" seems to be a big part of getting the engine balancing right.
I've also found having the engine solidly mounted helped. My theory at the time was that the original slightly flexible engine mount allowed the engine to get a "buzz" going. When solidly mounted it couldn't get the whole bike "buzzing". As has been said there is no real slid magic % as there are lots of factors affecting the vibrations. You should be reducing counterbalance on both the crankshaft and the balance shaft. In the direction of piston travel the masses act in unison but at 90 degrees they counteract each other. If you remove mass from only one then you will be altering that counteraction which is at 90 degrees to piston travel. Irrespective of piston weight and rpm they probably should remain at about the same ratio.
For what engine, Jürgen? Jan Schäffer of Langtuning or Martijn Stehouwer of Emot might be able to supply you with the type of piston plug you need.
Re the material: it'd not PEEK. I wish; the stuff I finally found most suitable is a lot more expensive.
The pics show the plugs in a FOS-piston and a comparison of the Pankl RSA-piston pin and a FOS-plug.
There are currently 48 users browsing this thread. (1 members and 47 guests)
