Page 1376 of 2773 FirstFirst ... 3768761276132613661374137513761377137813861426147618762376 ... LastLast
Results 20,626 to 20,640 of 41594
  1. #20626
    You would need to consider the rod width, surely? You couldn't go wrong using the RSA dimension. What rod was used, for comparison?
    Thnxs for response. My limited understanding is that in many cases the width of the rod (most almost usually the same top and bottom for mfg purposes) is the same as the piston pin diameter, ie a rod for a 14 mm pin is 14 wide. So, in our case, the rod would be 15 mm, which is narrower than either the 18 or 20 mm cage and accordingly the width between the pin bosses. In the narrower case, there is the likelihood for the ends of the rollers to be within the width of the rod eye under extreme end float situations.
    We'd even be happy if everyone said they have had no dramas with the narrow cage.
  2. #20627
    Look up the common size high performance little end bearings available and size it to suit them.
    15 x 19 x 16.7
    15 x 19 x 17.2
    15 x 19 x 17
    15 x 19 x 20
    15 x 19 x 20
  3. #20628
    31st July 2005 - 11:15
    a shed full of crazy shit
    That motor is a bit old hat now but hopefully will do the business again some day...
    Not so much lurking, just not much else to do these days...
    Ok, I'm going to bite...
    WTF is being built in that jig???
    I'm thinking aircraft-ish.... Gyro??
  4. #20629
    On end, aircraft engine mount. Firewall mounts are on the bottom.
  5. #20630
    Husa, thanks for the sizes, these are well documented, but really what we'd like to know "has anyone experienced the narrower cages shitting themselves when compared to the wider cages"?
  6. #20631
    Chokky fish to that man.
    http://www.lancair.com/legacy/
  7. #20632
    What are we looking at? An aircraft engine frame? Last picture. Oh, I need to read to the end before posting, sorry.
  8. #20633
    First two pics are Jasons rehash of the Steadman cocktail. And a fine job it was.
  9. #20634
    Only small end failures I've seen/had have been accopmanied with large amounts of deto, big end failures have been from copper plated M cages and not enough lubrication. Used slightly narrower and slightly wider cages big and small ends with no ill effects
  10. #20635
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    I've flown one of those! ...............where?...................Ardmore... .............. on MS flight Simulator
  11. #20636
Name:	Push and Go.jpg
    Chambers RG50 with a push and go ignition made by rewinding a race stater from a Loncin Race ignition for 12V to power the Ignitec. The Loncin rotor has a RG50 center bolted into it.
Name:	Chambers RG50 Boyesen Ports.JPG
    The cylinder was modified for full reeds, a boost port and Boyesen like ports that got through to the top of the B transfers.
Name:	Glass Blue CF Red.jpg
    The setup was run with two stage glass fiber reeds (Blue line) and heavier carbon fiber reeds (Red line).
Name:	Red plugged Boyesen Ports Glass Reeds.jpg
    Then to see if the Boyesen like ports were doing anything worth while they were blocked off (Red line). Lost a bunch of top end but picked up some useful drive coming onto the pipe.
Name:	Grn Boyesen + Boost-Transfer plugged.jpg
    Then the open duct between the boost port and B transfer ports was closed off (Red line).
Name:	Green Boyesen + Boost plugged.jpg
    Blue, first run, Boyesen and Boost Duct open. Red Boyesen closed. Green, Boysens blocked plus Boost and B Transfers blocked off from each other.
    The next move will be to keep the opening between the Boost and B Transfers blocked off and open the Boyesen like ducts up again.
    The ambition is to run an RG50 and go better than 15 rwhp with it.
    The last couple of weeks has all been about proving everything one step at a time..... After 160 plus runs the 85% width exhaust port is holding up well. so getting there bit by bit and lots more things to try, like an exhaust port floor dam and a new 14K+ rpm pipe.
  12. #20637
    Tell us about the ignition stator modifications Rob?
Name:	Promotional-flat-iron-rivets-iron-rivets-Hand-flat-head-rivet-iron-hair-nails-M4-8-M4.jpg
  13. #20638
    That's what I like to see. Testing mods. The amount of times I've reversed things that were a cert to be better yet weren't. Sometimes for a reason but at least you know.
  14. #20639
    The high voltage CDI winding's on the left were removed and the that side of the stater got a second set of 12V winding's.
    The Loncin hub cant be completely removed without breaking the magnets. So Chambers bored out the very center part and drilled out the rivets.
    Then the RG50 hub was glued and bolted in place. The rotor winds up being clamped between the RG50 hub and the remains of the original Loncin hub. It has worked a treat so far.
    I am not sure if there were any photos taken of the process but I will have a look to see if there is anything to post.
  15. #20640
    Luc Foekema ...facebook page is very good read plenty about 50cc engines.
There are currently 216 users browsing this thread. (0 members and 216 guests)
