Page 1380 of 2776 FirstFirst ... 3808801280133013701378137913801381138213901430148018802380 ... LastLast
Results 20,686 to 20,700 of 41630
  1. #20686
    9th June 2012 - 18:32
    Bucket Sidecar
    palmerston north
    Well the 2Ts didn't fare very well in the 2-hour race. Seems to be an opportunity to consider rule changes to even the playing field. That's how it works isn't it?
    Oh wait. 2Ts already have an unfair advantage
    Changed my mind on that one. Malcolm was impressed with our 2t, maybe we will just run with it anyway...
    Cheers for helping out with the monetary issue after the race TZ, very sporting of you!
    Rock on.
  2. #20687
    7th November 2013 - 19:37
    gpr150
    palmerston north
    They must have learned how to blip between downchanges
    Ha ha that's the one I don't no what i have been up to all them years
  3. #20688
    gpr150
    palmerston north
    The only bike with a wobbly set up what can I say
  4. #20689
    18th July 2015 - 16:21
    2015 Avanti
    circlip grooves
    This is how I cut the circlip grooves into the pistons.
    The groove tool is 0.42mm wide for 0.4mm wire circlips.
    I groove 0.23mm deep or 0.46mm diameter from touch. I like to tape the outer edge of piston crown just to make sure
    I do not damage the seal band or top edge.
    When clipping finished pistons, I make a plastic piston clamp, and put a paper washer between the piston and the fixture.
    Normally I would put the circlips in before finishing the pistons, but this time did them afterwards.
    Neil
ID:	317459   Click image for larger version.
  5. #20690
    10th June 2008 - 21:54
    honda ct now FXR SCORPA SY 250
    wellington
    Thanks for the report Rob. Great to see some of the Welly/Palmy boys doing well. How did the GPR 2T go? Kel your bike is looking very nice. You going to race in the Sandbaggers race this year?
  6. #20691
    Bucket Sidecar
    palmerston north
    Quote Originally Posted by steamroller View Post
    Don't be mean! It's a new concept.
    Folds easily for storage in a wheelie bin.
  7. #20692
    Bucket Sidecar
    palmerston north
    Quote Originally Posted by andrew a View Post
    Regan can reply to that, apparently it went well, but they were a bit rough with the new baby.
    Bad Regan. Don't start it with a pistol drill again, bad bad Regan.
  8. #20693
    How do you figure that? You need to take your axe and grind it somewhere else.
  9. #20694
    Bucket Sidecar
    palmerston north
    It's all good humour, as we all know, every racer does what suits their own style, and their bikes set up.
    If life was all one notion, it would get boring very fast.
    Lets all enjoy the sport with good humour, good comradeship, and let this moment give us all determination to keep up the spirit of buckets. Was thrilled to hear TZ's reaction to the day, the sport is a bit more then our occasional ribbing.
    But it does give us the odd laugh or two.
  10. #20695
    2nd July 2013 - 11:52
    GPR150
    palmertson north
    Without question the quickest bike out there (in a straight line). Was the riders handicapping that rocket ship.
    i must say , you bike dose look nice , and in green
    i'm over buckets
  11. #20696
    gpr150
    palmerston north
    It went very good could not have gone any better. Gary did the bluff roll of the dice and after that the pick up for the motor did shear off. Kerry has done an awesome job of the CNC barrel, really looking forward to racing it. Team GPR build 4 strokes and 2 strokes
  12. #20697
    Page 1380 ...
    Quote Originally Posted by rodg View Post
    ... increased the air correction jet diameter and up the main worked a treat providing a small increase in power everywhere.
    Attachment 317487
    Red line best power with the original main and 1.25 air correction jet. Blue line, 1.45 air correction plus bigger main jet.
    Great to have such a clear result of what can be achieved by adjusting the air correction jet to bend the fueling curve.
    ... http://www.highwaymanbikes.com/ I have linked some of his work before.
    I am not Rob (TZ350)but Robinson covered it.
    Remember carbs have over lapping circuits the air jet is used to compensate for the rate at which the fuelling of the main circuit is controlled by an increase in high speed airflow.
  13. #20698
Name:	2 Hour 2015 042.jpg
    The GPR 2T looks good and went very well but the ignition trigger rotor broke loose.
Name:	2 Hour 2015 038.jpg
    Apparently it came away after the bike had been started several times using a battery drill to spin it over by the crank nut.
    Not a biggie, with any new build there are always little issues that need to be resolved.
  14. #20699
    Bucket Sidecar
    palmerston north
    There's always teething problems, everyone's been there before!
  15. #20700
    The peak of bucket chassis development is certainly the GPR chassis at the moment. Very nice units.
    That 2T motor looks very "competitive" with it's little built-in water pump housing.
There are currently 226 users browsing this thread. (0 members and 226 guests)
